Rocker arm adjustment.
Old Dec 18, 2008 | 08:28 PM
VTEC1n2nd's Avatar
Default Rocker arm adjustment.
SO my rocker arms make a ton of noise on my d16y8 when i get around 3k RPM. It gets annoying after a while. Is there any way to adjust them?
Old Dec 18, 2008 | 09:27 PM
Jimster480's Avatar
mine just whine. But then again my motor is just beat. Which is why im swapping it out of there lol.
Old Dec 18, 2008 | 09:42 PM
Ruben19's Avatar
this is call a valve adjustment job.
Old Dec 19, 2008 | 05:39 AM
Jimster480's Avatar
mine needs more than that.
Old Dec 19, 2008 | 05:55 AM
z6hatchboy's Avatar
for the op, to do a valve lash adlustment. Take the v/c off and at the end of the rocker arm will be a lock nut and lash adjuster that goes does to the valve. Loosen the lock nut with a 8 or 10mm wrench, use a feeler gauge between the valve and adjuster and adjust the aduster to spec. I think the inake is .008" and the exhaust is .012"..i tihnk but go look your up and make sure
W.O.P.
Oct 18, 2024 05:32 AM
Big red89
Dec 18, 2007 10:44 AM
jtchinoy
Jun 26, 2006 09:26 PM
Hawkze_2.3
Jul 30, 2004 06:32 PM
draco067
Mar 11, 2003 07:18 AM
