Spoon b16a swap temp problem
Old Dec 18, 2008 | 08:03 PM
brent_si's Avatar
Default Spoon b16a swap temp problem
I just swapped in a spoon b16a into my em1. When im driving the car it never gets into the normal range its always below. I haven't really checked anything because have seen a lot of snow lately. A solution or a checklist would be great thanks.
Old Dec 18, 2008 | 08:14 PM
THC07's Avatar
make sure there even is a thermostat. maybe its stuck open
Old Dec 18, 2008 | 08:47 PM
Frickr's Avatar
i thought the spoon motors run a colder thermostat? must have more coin then i do, i can hardly pay for gas...
Old Dec 20, 2008 | 06:40 PM
brent_si's Avatar
yes I have heard that they run a colder thermo. from what I seen the oem honda thermo opens at 78 C and the spoon is 65 C. But even at 65 it should still be up in the normal range on a 00 si cluster correct? The only time it gets over the first white line is when I get above 9k rpm. Which has only been once because a test pipe is so stupid loud at that rpm lol.
Old Dec 20, 2008 | 07:22 PM
Mashimaro's Avatar
sounds like you need a new thermostat. change it out for a brand new one.
cmdr430
Honda S2000
40
Mar 30, 2004 09:07 PM
mckenzie
Mar 9, 2004 06:08 PM
sivik2nr
Feb 3, 2003 04:04 PM
IN VTEC
Oct 27, 2002 01:13 AM
austrian type-R
Feb 6, 2002 09:10 AM
