squeaky clutch pedal
Hey, For some reason my pedal has developed a very annoying squeak. It was small at first but has gotten louder, any ideas what might be causing this?
It is definitely cooming from the pedal area
well I thought I ought to let you guys know that I fixed it, just in case some one wants to try it on theirs.
I bought a can of lube at walmart for about 2 bucks, it's called white lightening or something. lubricant. I just sprayed all around that area, and used a straw to get to the cable guide hole. Pretty much sprayed all friction areas and through the engine bay I diconnected the cable and sprayed inside the cable.
let it dry and now no squeak =]
that white lightening is white lithium grease in a spray can. I've got some in the garage.
You picked the right thing: white lithium is exactly what you should be using on your pedal assembly; not wd40, 3 in 1 oil, motor oil, or ARP moly lube.
but it supposedly makes a film
The_PissingDog_Crx
May 17, 2003 12:50 AM
