Inoperable Dash Lights
Old Dec 18, 2008 | 03:34 PM
Luchini's Avatar
Default Inoperable Dash Lights
Have a 94 Civic EX coupe. The dash and heater lights often dont work unless I bang on the light dimmer switch. I was thinking there is a faulty relay or wiring in that area. Does anyone have any experience with this? I heard this is a common issue among 92-95 civics.
Old Dec 18, 2008 | 06:17 PM
freakasis's Avatar
change the dimmer switch and when you do inspect the wires around it
Old Dec 18, 2008 | 11:57 PM
Luchini's Avatar
Do you have to take the dash off to do it? How do I get to the switch?
Old Dec 18, 2008 | 11:58 PM
69NOSAJ's Avatar
just keep bangin it, no worries
j/k
g/l
Old Dec 19, 2008 | 05:54 PM
freakasis's Avatar
i think you can reach up under the dash and push it out. if not you might have to take the cluster and bezel out and rear in there. but try prying it out with a screw driver first. be sure to put a rag in between the dash and the screw driver so you dont scratch it.
Old Dec 19, 2008 | 09:47 PM
SOHC_4dr's Avatar
i have a similar situation. only i had to hit the dash not the dimmer switch. only now they wont turn on at all. i think if you take the cluster out you can reach behind it and push it out. not sure on that though. i still have the same issue though. i have checked wires as well and still can't find the issue.
vartok
May 20, 2014 04:28 AM
cmwalker
Jan 17, 2014 12:06 PM
Crewdog60M
Dec 10, 2012 08:38 AM
soccergk
Feb 21, 2007 12:25 PM
7808
Dec 18, 2005 06:50 PM
