adjustable ball joints vs upper control arms for lowerin
Old Dec 18, 2008 | 12:55 PM
lsrex10's Avatar
Default adjustable ball joints vs upper control arms for lowerin
im tryin to decide which is a better way to go with a camber kit on my 89 crx an i want to know if adjustable joints are a good way to go our just get the whole upper arm so let me know what you guys think
Old Dec 18, 2008 | 01:15 PM
_Keith_'s Avatar
Have you found upper set for a ef?
Post links
BLU CIVIC's Avatar
Track Advocate
both work good
Old Dec 18, 2008 | 02:17 PM
Tyson's Avatar
you lose suspension travel with the adjustable balljoints. adds height ot the balljoint, so it hits the top of the fender. plus they look kinda weak....
skunk2 is the only maker of adjustable a-arms that fit. hard to find because theyre in demand.
are you going to get an alignment?
Old Dec 18, 2008 | 02:31 PM
acmoc's Avatar
skunk2 makes real good ones, and weksos has them in stock
Old Dec 18, 2008 | 02:36 PM
Targa250R's Avatar
be professional
Why do you think you need a camber adjuster kit?
Old Dec 18, 2008 | 02:45 PM
Tyson's Avatar
targa's picking a fight! :D
heres a recent one.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/when-i-put-front-camber-kit-2451883/
sick em boy, sick em!
Old Dec 18, 2008 | 02:52 PM
CBEengineering's Avatar
ive had my revo adjustable arms for a year now no problems (bent inside of pinch weld and swapped to ES ball joint boots)
Old Dec 18, 2008 | 03:24 PM
Tyson's Avatar
i thought revo's hit the inside fender.
Old Dec 18, 2008 | 03:41 PM
allgo88's Avatar
i had skank on my teg.they were great.i have revo's on my rex,and there just as good.there both upper control arms with adj ball joints.no mater what you use,if you want 3degrees of adj your going to have to do some bangging on the inner fender lip.
Old Dec 18, 2008 | 03:51 PM
they hit the pinch weld so i banged it out a lil. i have da knuckles. dont know if that matters. im not super low either 1 1/2<>2 finger gap.
Old Dec 18, 2008 | 03:54 PM
Tyson's Avatar
ic. so one could grind just a bit of material off too. good to know.
was it also some Rhino brand that made arms for the CRX? is that hte same as Revo?
i installed some skunk2 arms on a friends car. seemed to fit fine. at extreme upper angle, and balljoint adjusted all the way in, the knuckle would interfere with the arm inside the "cup" of the arm. but not a big deal. cleared the inner fender JUST enough.
the DA knuckles wouldnt affect the fitment.
Old Dec 18, 2008 | 04:25 PM
the rhinos looked too cheap for my tastes..im a middle of the road kinda guy.
ive just heard they were taller.
Old Dec 18, 2008 | 04:30 PM
Tyson's Avatar
yeah they are, but it wouldnt affect whether the A arm hits the fender.
Old Dec 18, 2008 | 05:20 PM
Targa250R's Avatar
be professional
heres a recent one.
https://honda-tech.com/forums/showthread.php?t=2451883
I just finished installing a new pair of trailing arm bushings and I'm still pumped. Maybe I should go drop the trans and install a new inboard mainshaft bearing to cool down; then I won't have enough energy left to explain unpopular concepts.
Old Dec 18, 2008 | 06:06 PM
4DRmafia's Avatar
Keep the stock upper arms if you have da kunckles in.
Old Dec 18, 2008 | 06:15 PM
CRX Toad's Avatar
Show off
Old Dec 18, 2008 | 06:40 PM
Tyson's Avatar
i think you have the wrong thread.
Old Dec 18, 2008 | 07:01 PM
Jonny Rocket's Avatar
why you say that?? I have DA knuckles and soon to lower my ride and get the Skunk2 Adjustable A-arms on my 90 hatch dx
Old Dec 18, 2008 | 07:57 PM
4DRmafia's Avatar
Would have a positive camber if sitting at stock height and then when you lower it, it help straight out the camber.
Old Dec 18, 2008 | 08:03 PM
Targa250R's Avatar
be professional
Actually, the taller DA knuckle puts the upper control arm at a larger spread relative to the position of the lower control arm, which results in a more aggressive camber curve (ahh, the beauty of SLA double wishbone suspension). This means that while the camber will be more positive at stock ride height, it will be even more negative than normal at lowered heights. The upper control arm will also have a higher static position than normal, so it will hit the underside of the shock tower sooner under compression. That is why the reduction in clearance caused by a taller adjustable ball joint is not good.
crx_si-r
Jun 7, 2010 09:29 PM
civicgeek133
Suspension & Brakes
12
Nov 26, 2006 06:40 PM
IntegraFanatic
Apr 6, 2004 11:15 AM
spencedogg
Jan 23, 2004 12:18 PM
SilverIntegra
Nov 30, 2002 02:10 PM
