Need help!!!
Old Dec 18, 2008 | 02:54 AM
afterdark's Avatar
Default Need help!!!
How can i tell apart if the wire harness is obd1 or obd2???
Old Dec 18, 2008 | 07:59 AM
mouab18c1's Avatar
what harness?
Old Dec 18, 2008 | 02:32 PM
afterdark's Avatar
the engine harness
Old Dec 18, 2008 | 05:19 PM
mouab18c1's Avatar
Originally Posted by afterdark
the engine harness
what model? like integra gsr or ls or civic harnesses? what car and motor do you have? what engine are you tryng to get a harness from?
Old Dec 18, 2008 | 10:19 PM
afterdark's Avatar
well i have a 98 jdm b20 in a civic hatch
and i ask cuz i would also like to know how to tell from any car or engine.
is there a diagram or something that show how to tell apart??
and also i wanna know how to tell jdm engines from usdm engines cuz idk if this guy is sellin me a legit jdm gsr longblock.
Old Dec 19, 2008 | 09:48 AM
mouab18c1's Avatar
well im sure if you search you can find diagrams but then from obd1 to obd2...obd1 harness have to plugs for the distributor while the obd2 only has one...if your using a vtec harness on a non vtec motor then youll have the vtec plug unplugged...and if your using a non vtec harness on a vtec motor then you would have to wire it straight to the ecu...
to determine if the guy is selling you a legit jdm gsr block it should be stamped b18c on it..usdm gsr are b18c1
Old Dec 19, 2008 | 02:16 PM
afterdark's Avatar
ok thanks for the info
Old Dec 19, 2008 | 03:14 PM
mmuller's Avatar
Mad Scientist
injector plugs are different, obd1's are usually gray and the ones that lock with the c clip; obd2 's black in color and has push tabs on the sides
distributor plugs, obd1 has 2 connectors and obd2 has 1
obd2 will have a crank sensor plug on it
some differences
cnydc2
Jul 15, 2009 05:10 AM
Skillz
Sep 17, 2006 08:31 PM
3k9civic
Feb 1, 2005 09:02 PM
tallblondkid
Oct 14, 2004 06:35 PM
