What should i use to clean my clocks plastic face cover?
Old Dec 17, 2008 | 06:23 PM
JDM_SOHC's Avatar
Default What should i use to clean my clocks plastic face cover?
It's smeared looking with blurry spots all over it, tried to clean it with alcohol but no luck at all... Anyone kno what i could do to perhaps make it look new again..?? I just picked it up for $5 at junkyard, so hopefully I can turn it into not such an eye sore lol...
Old Dec 17, 2008 | 06:25 PM
hondatec1's Avatar
try s0me wax
Old Dec 17, 2008 | 06:33 PM
ejLday's Avatar
not sure but I bet the guys in the detailing forum would know
Old Dec 17, 2008 | 07:08 PM
JDM_SOHC's Avatar
i posted there... hopefully someone will knoo...!
Old Dec 17, 2008 | 07:49 PM
ejLday's Avatar
is it scratched?
Old Dec 17, 2008 | 08:00 PM
evade_07's Avatar
it looks like condensation on the inside of the clock to me but if its on the exterior, just get a high grit sandpaper, a old t shirt, cloth, or rag and some rubbing compound.
sand it down gently, then apply some rubbing compound and use some elbow grease. that will work if its on the exterior of the clock. if not your gonna need a new one
Old Dec 17, 2008 | 08:01 PM
ejLday's Avatar
i cant tell what it is
Old Dec 17, 2008 | 08:22 PM
OneFire's Avatar
OP, try out Meguiars Plastx first before you start sanding anything. The Plastx did awesome on my clouded headlights. I didn't even have to sand. They also polished and took away scratches from my window visors.
Even if it doesn't work you can use what you have to clean your headlights, taillights and any other plastic you have. Like gauge cluster cover etc.
Old Dec 17, 2008 | 08:27 PM
ejLday's Avatar
bump! I need to get some of that
Old Dec 17, 2008 | 08:32 PM
SikofFalln's Avatar
Toothpaste.
Old Dec 17, 2008 | 08:34 PM
evade_07's Avatar
yup that plastix stuff is the rubbing compound i used on my old dc, works good.
Old Dec 18, 2008 | 12:03 PM
JDM_SOHC's Avatar
can i get that **** at autozone..?? sounds like a pretty high % of u guys say plastix is the way to go... u kno when u spray black magic on ur tires, than go for a ride and it leaves that smeary residue on ur fender and ****, than u gotta wipe it off..?? thats what it looks like, only on the lense cover of the clock, its like a buncha small circles like someone sprayed cleaner on there and never wiped it off...
Old Dec 18, 2008 | 12:22 PM
bokals's Avatar
Yes, you can get that "****" at autozone, its like 7 dollars...
honestly just go and buy another one from the junkyard
Old Dec 18, 2008 | 12:51 PM
JDM_SOHC's Avatar
ima go snag some of that plastix stuff up right now, i just called a detail shop and they mentioned that too... thanx a lot guys..!!
might even throw an amber folder tab in there to spice up the JDM'ness hahaha... seen the DIY in my search for cleaning the lense...
Old Dec 18, 2008 | 01:04 PM
ieatrice's Avatar
this stuff is the shiznit! the headlights on my s2k were so fugged up.. i tried all sorts of products, but as soon as i put the plastX on and rubbed away.. everything looks brand new again!!!
JDM_SOHC
Detailing
16
Apr 25, 2009 03:27 PM
JDM_SOHC
Dec 18, 2008 12:04 PM
caliskier
Jan 26, 2008 12:14 PM
99delsol
Sep 22, 2006 01:01 PM
SunshineCivic
Audio / Security / Video
12
Sep 3, 2006 05:50 AM
