Clicking when I turn.
Old Dec 17, 2008 | 03:16 PM
raffydogg's Avatar
Default Clicking when I turn.
1995 Honda Accord EX coupe.
5 speed, 2.2 V Tec
When I make left turns I hear this light clicking or knocking.
It doesn't happen on every left turn, but it does happen.
Any idea what it could be??
Old Dec 17, 2008 | 03:27 PM
jdm602's Avatar
axles.
Old Dec 17, 2008 | 04:09 PM
charliebcdaccord's Avatar
Post axles
check your drive axles. Check to see if the boot is cracked and if there is grease all over the inside of the rim
Old Dec 17, 2008 | 08:53 PM
gosu08's Avatar
it could also be your cv joints as well (most cases)
Old Dec 18, 2008 | 09:27 AM
flight50's Avatar
if you can't pin point the exact problem, just replace the whole axle. i remember getting a remanu. one for less than 50 bucks with a lifetime warrant once. make sure you have the little clip on the end that goes in the tranny when you reinstall it.
Old Dec 18, 2008 | 09:45 AM
jdm602's Avatar
most likely an axle, and yes dont forget the set ring. otherwise the axle can come outta the tranny.
tamadrummer1120
Oct 13, 2009 07:48 AM
accord99power
May 12, 2009 05:14 PM
griz50cal
May 5, 2007 07:22 PM
mingbling96
Mar 13, 2005 08:14 AM
leadfoot78
May 26, 2003 12:17 PM
