B16 Bogging when I goose it
Old Dec 16, 2008 | 11:46 PM
gringo7718's Avatar
Default B16 Bogging when I goose it
When I am driving in 3-4-5 gear at low to mid rpm and I suddenly increase load the engine boggs for a second or two before it starts picking up. Sometimes it randomly breaks up a little in the higher rpms.
I checked my TPS and my MAP and they are fine.
Does this sound like a fuel or spark issue?
Old Dec 17, 2008 | 12:22 AM
acmoc's Avatar
both, maybe bad fpr,filter, check the cheap stuff first, vaccuum leaks
plugs wires rotor cap
Old Dec 17, 2008 | 07:39 AM
gringo7718's Avatar
Alright I checked my timing and its on point at 16 BTC.
I will replace the fuel filter later today.
Old Dec 17, 2008 | 01:25 PM
gringo7718's Avatar
I got a chance to look at it today and I decided to test the voltage at the TPS.
It should read .5 volts when closed and 4.5 volts at WOT.
My readings were reversed so I thought maybe there was a typo in my research. I would see 4.5 volts closed and .5 volts at WOT. So i figured out that my power and ground for the TPS were backwards and that fixed my problem. I did not have a CEL and the car ran really well so I thought that was weird.
for further clarification
Old Dec 17, 2008 | 01:32 PM
AJxr's Avatar
what ecu?
Old Dec 20, 2008 | 09:06 AM
gringo7718's Avatar
I have a PW0 ecu.
Much better now! I cant believe the polarity was backwards - that means when i was at WOT the ecu thought the throttle body was closed.
I just thought it was really strange because I had no cell and the car drove fine otherwise.
GT500FTW
13
Sep 4, 2012 05:51 PM
strictlyimport
Apr 12, 2006 04:51 PM
ef8b16a1
Feb 15, 2006 05:01 PM
highperboi
Jan 6, 2006 02:50 AM
k_spec
Jun 9, 2005 09:00 PM
