rod bolts?
Old Dec 16, 2008 | 11:23 PM
columbushatch's Avatar
Default rod bolts?
I have installed the Tuner Toys d16 rod and have already ran it for 2000 miles. I torque down the rod bolts to 37ft/lbs (Stated on TT website). I occasionally redline it a couple of time to see if the motor holds up and its still running strong. I am in the process of installing a turbo and was wondering if I should retorque them the correct way (loosen-tighten method or stretch gauge)? will it still hold up under boost if I left it alone? and if not, are the bolts still good for me to retorque them?
Old Dec 17, 2008 | 03:36 AM
non-VTEC's Avatar
you do not need to re-torque rod bolts. if you do you are asking for big trouble.
just leave them alone. they should be fine.
Old Dec 17, 2008 | 08:57 PM
I hope its going to stay intact. I already spent too much money and don't want it to fail on the dyno. anymore opinions?
Old Dec 17, 2008 | 09:13 PM
DC4KiD's Avatar
If you [think you did] did it right the first time around, you should be fine with it now.
Old Dec 18, 2008 | 08:38 AM
thats the thing, I didn't do it right. the right way is to use a stretch gauge and I only torque it down once to the specs provided but torque wrenches can be inaccurate. The problem is that its been running strong (unboosted) and I don't know if its ok to leave it like that when boosting.
Old Dec 18, 2008 | 08:53 AM
tegman23's Avatar
If the rod bolts were torqued down @ 37ftlbs you will be fine...Even in the wrench only tq them down to 36ftlbs you will still be ok lol
Old Dec 18, 2008 | 09:23 AM
thanks for the reply, kind of ease my mind a little
Old Dec 18, 2008 | 11:42 AM
Fabian's Avatar
strech gauge is the way to go imo.
Old Dec 18, 2008 | 12:36 PM
riceburner700's Avatar
if you can get one to fit in a d-series^^
Old Dec 18, 2008 | 07:05 PM
Scott_Tucker's Avatar
A turbo is not going to add much additional stress to the rod bolts anyway. If a rod bolt is going to fail, it's going to fail at TDC on the exhaust stroke when there isn't any pressure in the cylinder anyway. If anything backpressure at high rpm due to the turbo will decrease the tension on the rod bolts at TDC on the exhaust stroke.
That said, the most accurate way to pre-tension (this is what you are doing when you 'torque' a bolt) a rod bolt is with a stretch gauge.
Old Dec 19, 2008 | 06:38 AM
^^^ so does that mean that if it already last, it should be ok boosted. I didn't realize about the stretch gauge method until after i install the rods. should I do anything to them now?
hatchyboy89
Aug 6, 2010 08:11 AM
092eg6
Mar 30, 2010 12:16 PM
Tech6023
Sep 22, 2005 06:40 PM
Mover
Sep 23, 2002 02:27 PM
