2001 GSR w/ skunk2 manifold
alright, i'm completely stumped.
i'm working on a friends 2001 gsr, it has i/h/e, and i pulled his manifold and replaced with a gen1 skunk2. the car has almost no throttle response (sputters when giving too much throttle). smells like it's running rich, and well, i can't find any vacuum leaks. i've tried running (out of curiousity and troubleshooting) the stock p72...dies at idle. i've tried a p28 w/ a modded ITR program from my perfectly running car and it runs a lil rough at idle and does like mentioned above..cant give it throttle without it hesitating. am i chasing a non-existent vacuum leak, or is something going on without these IAB's present? i need help!
thanks in advance..
thanks in advance..
thanks in advance..
thanks in advance..
first run at the p28 - no, second time yes..but i'm unsure of how to read codes on obd2 car with obd1 ecu :/
first time running the car was idle to running temperature to check for leaks..tried to rev it at running temp = fail. (no CEL)
second run i didn't change anything at all, ran exactly the same but the CEL stayed on.
third run p72, ran for 2 seconds and died.
That would be your best bet.
i have a feeling the chip i was running for him (my chip) might have had something enabled/disabled that the gsr needs. i'm running a mild build itr that was tuned probably 3 years ago by me and i cant remember what i did to that program..haha. it feels good on the butt dyno, and looks good on the wideband..
can you elaborate? i haven't touched or unbolted anything on the throttle body..
as a side note, 5 minutes ago i tried running it and unplugging one sensor at a time, it all ran the same with iacv unplugged, then iat, then map, then when i unplugged the tps, it died.
it has burnt A LOT of fuel..had a quarter tank the other night, after being run for maybe 30 min total it's ON E.
ended up burning 3 bad chips, somehow they just went bad. i busted a brand new one out and burnt stock itr and it ran perfect.. took a while to burn off all the extra fuel in the intake manifold from being run rich.
thanks for the suggestions though guys.. i feel retarded. hah.
Halo
10
Jun 19, 2002 06:56 PM
