need help asap obd2b immobilizer
Old Dec 16, 2008 | 08:04 PM
bleedblue94's Avatar
Default need help asap obd2b immobilizer
hey im putting a b20z into a 00 civic... everything is done except the car wont run on the obd2b p75 ecu bc of the immobilizer... can someone tell me how i can remove the immobilizer in the ecu or bypass it? id rather just remove the chip off the board but i need someone to tell me which it is ect and if that would effectively bypass the problem... thanks guys
Old Dec 16, 2008 | 08:39 PM
Jas9848's Avatar
im not sure how to remove the chip or disable it. get an obd1 ecu and jumper harness
Old Dec 16, 2008 | 10:45 PM
dont want to and cant... nys emissions requires obd2 ecus in obd2 cars... so i need to make this work... or ill do an obd2b to obd2a harness and run the obd2a p75 wo the immobilizer but id like to know if there is a wway to remove the chip from this ecu
Old Dec 17, 2008 | 01:32 PM
MenaceL.A.671's Avatar
yes you can remove the immobilizer but you'll have a check engine light on!
what i did was i transfer my immobilizer from my gsr ecu onto my usdm itr 73 ecu and it works well with no check engine light. and i have a 2000 integra. but your in a different story, you have a civic so if you remove the chip, like i said earlier you;ll have a check engine light!
other option would be get a jumper harness obd2b to obd2a!
Old Dec 17, 2008 | 02:58 PM
yeah im considering the jumper harness... im wondering though if i remove the immoblizer chip is there a resistor or something i can soilder on the board to bypass the check engine light?
Old Dec 17, 2008 | 04:07 PM
Katman's Avatar
not that i know of...
going OBD2a would be the best thing to do in your situation.
Old Dec 17, 2008 | 10:53 PM
thanks ... thats what ive been thinking... do you or anyone you know sell an obd2b to obd2a harness for cheap??
Old Dec 18, 2008 | 11:32 AM
Blown90hatcH's Avatar
What he said. OBD2b-2a harness here
Old Dec 18, 2008 | 02:41 PM
can go with rywire! i think jhpusa.com selling rywire harness cheaper!
Pimpsherm2009
Jan 13, 2010 06:05 PM
Rob97'SH
Engine Management and Tuning
Dec 18, 2008 04:15 AM
sileighty_911
Dec 28, 2006 08:58 PM
gsrintegra18
Sep 22, 2006 08:16 AM
