k series Q's
Old Dec 16, 2008 | 04:36 PM
RudeLudeHatch's Avatar
Default k series Q's
Alright well im going to build a k27 drag motor and have a few questions. I plan on using the crv/accord block. I plan on using a performance oil cooler and electric water pump so i dont have to worrie about switching those parts. Does anyone know if there is a company that has made a oil sump tank kit for the k eseries? Can i run my RHD throttle cable with the swap? Has anyone heard about the guy at hytech that blueprints k24 oil pumps and sets them up the right way? Or just go with the Erl modified f20 pump with upgraded spring. Does the ep3 head and the type s head the same casting? Can a ep3 head be ported and built the same as a type s head i should say. Trying to save some money. Very last question what company can i go through to gear my trany for the track? Appericate the help guys
Old Dec 16, 2008 | 05:03 PM
bump
Old Dec 16, 2008 | 06:08 PM
6SPD_EK's Avatar
what crank? you are talking about 105+mm stroke ($1500+)
a dry sump? thats $2000+
maybe but you are talking about replacing a $20 part
Hytech mods type-s/r k20 oil pumps to flow to 9k
the erl is a mod'd s2k pump - I don't believe the spring is modified. this will flow to 9.5K.... either way you wouldn't need these with a dry sump so why does it matter. I would not run either type-s/r or s2k on any type of motor you are talking about here
No
it can come close but not better
with a "2.7" build... yeah right you are looking at $20,000 for setup. probably more when you throw all the necessary swap parts IE axles header, mounts, K-pro
way to many variables not too mention you would be breaking any tranny you use.... OFTEN!!!! so go oem
Old Dec 16, 2008 | 06:46 PM
I know dry sumps are pricey but im gonna run one. What is the best choice of oil pump i can run untill i find a dry sump. My eg is RHD so i wanted to know if that is going to work or if i need to get a RHD K series cable. So your saying that the oem tsx tranny is geared good enough for the quarter mile. What is the stamp on the type s head or the code so i know that it is a type s or ep3. Thanks
Old Dec 16, 2008 | 06:50 PM
andoxviii's Avatar
Whoa. Hopefully you can make it an automatic because you're going to be selling one of your legs for medical experiments to pay for it...
Old Dec 16, 2008 | 07:03 PM
I just go done selling one of my RHD's and a semi built H series swap so i got the dough. Might have to wait on my straight axle and lexan for a bit though.
Old Dec 16, 2008 | 09:16 PM
butter99's Avatar
Lota money for an oil pan, but if you have the budget for it then DO IT and post pics when its all done! I wanna see this crazy k-series.
Old Dec 17, 2008 | 02:07 AM
SHG_Claudio's Avatar
wow, whats the purpose of dropping 20k on a drag car? Fun? I hope you at least win races and make up for it lol.
Old Dec 17, 2008 | 02:15 AM
finkl's Avatar
i hope this is for drag purpose only. because with that much money and the power its going to put out. the car is no way streetable, let alone using pump gas. ur going to be using race fuel.
Old Dec 17, 2008 | 02:20 AM
ALL MOTOR EM2's Avatar
or E85
ACCORDingly94
Engine Machining & Assembly
Oct 2, 2015 12:28 PM
Dikon0901
Aug 25, 2013 01:55 PM
speedciv
10
May 20, 2011 10:33 PM
Mrclutch
Jun 27, 2007 06:45 AM
JohnnysEG
Feb 16, 2004 06:40 PM
