My fully built GSR TURBO setup. a little preview.
Old Dec 16, 2008 | 03:32 PM
itsjdm's Avatar
Default My fully built GSR TURBO setup. a little preview.
sup, i am putting together a little gsr turbo on the side for a little project. I have a b18c1 stock sleeve block with a gsr head. As far as the mods i will put a list with my estimated guest of what im looking to make.
B18c1 Stock sleeve short block
B18c1 resurfaced head
Ferra valves
Ferra retainers
Skunk2 Stage 2 camshafts
AEM Adjustable cam gears
Wiesco 9:1 comp pistons ( with rings )
Eagle rods
Cosmetic Head gasket
ARP Head studs
GSR Crankshaft micro poslished and balanced
ACT 4 puck clutch kit with 8lb flywheel
Turbonetics GTK450 Turbocharger
Treadstone Turbo manifold
Custom 3" downpipe
Tial 38mm external wastegate
HKS SSQV Bov
Treadstone Intercooler 3" thick
Intercooler piping
3" exhaust
and a billion clamps lol
Trying to make 430whp in a EF hatch
Old Dec 16, 2008 | 05:58 PM
1EG2NV's Avatar
Good luck bro! Should be no problem there!!
Old Dec 16, 2008 | 07:57 PM
fishieman's Avatar
where is the tech ? at?
Old Dec 16, 2008 | 08:06 PM
BiggieBert's Avatar
Loved
Community Favorite
Pics!
Old Dec 16, 2008 | 10:51 PM
SD_Lurker's Avatar
HT White Ops
I would stay away from the LOG manifolds. Not to say they won't make the power your looking for but they are pretty shitty to say the least. A ramhorn or miniram would suit you best IMO. If you were looking to make 300-350 then sure get a log but anything above that I wouldn't recommend it, not at all. Also, you don't need S2S2 cams, GSR or Type R's will be more than enough. Save the money on the cams and buy a better manifold, thats your best bet.
Old Dec 16, 2008 | 11:14 PM
jdm602's Avatar
agreed, ramhorn, topmount, or even something custom. it would be way more efficient and gain a lot more power with a different manifold.
and again i see all these people building motors, i know stock motors pushing more than that goal, but yes 430 should deff be an easy goal.
goodluck with the setup!
Old Dec 17, 2008 | 09:12 AM
HiProfile's Avatar
Originally Posted by fishieman
what is the tech ? at?
Same question here. This is a place to ask questions or post results, not to post a list of your future setup. You can use the photo album/garage section to do that.
Old Dec 17, 2008 | 09:13 AM
amimaxima's Avatar
pictures
Old Dec 19, 2008 | 09:28 AM
XKINGX's Avatar
bump
Old Dec 19, 2008 | 04:16 PM
black_EM1's Avatar
Community Builder
Community Influencer
Don't bump no-tech threads.
Old Dec 19, 2008 | 04:27 PM
blaze the chemi's Avatar
Here's the tech...
Why would you buy Ferrera valves and retainers and not upgrade the valve springs? Just wondering why you'd "rebuild" a head and use your OEM springs. Any benefit in this?
I would also just keep your head the way it is and put the money somewhere else.
Old Dec 19, 2008 | 05:00 PM
2000CTRSi's Avatar
Stronger springs mabye?... Stockers on w/ that valvetrain... just get some BC springs, they are cheap!
Recommend a better mani for the 4+ mark.
killacamcivic
Mar 14, 2012 05:47 PM
DA 4 Lyfe
Sep 4, 2011 03:22 AM
rico892002
May 16, 2011 07:19 AM
sdobson910
Apr 20, 2011 03:59 PM
