boosting my GSR
Old Dec 16, 2008 | 07:51 AM
JBLAZE622's Avatar
Default boosting my GSR
i currently have a 97 civic coupe with a b16 that has a simple turbo setup on it i also have a 94 GSR that i'm gonna swap the turbo setup on from the civic to the integra i was wondering if a b16 and gsr oil pan are interchangeable so i can use the b16 oil pan on the gsr engine
Old Dec 16, 2008 | 11:44 AM
Ruben19's Avatar
you cant use the b16 oil pan in the gsr engine.
wont fit
Old Dec 21, 2008 | 04:45 PM
boostedblkef's Avatar
Default Re: boosting my GSR
i beleive there the same bolt pattern but the oil pick up is diferent so im assuming that the pickup could be swapped also its not like honda to use tons off different parts but im not 100% sure on it
Old Dec 28, 2008 | 08:27 AM
romerosi's Avatar
well the gsr has a gurdle that holds the bottome end togher it wont clear
Old Dec 28, 2008 | 11:52 AM
DonF's Avatar
I am glad you are not sure. Because they are not interchangeable.Just more bad advice as usual.
motormike40
May 24, 2010 06:56 AM
shortstopNE
May 5, 2009 06:11 PM
11secteg
May 10, 2007 10:12 PM
dkim48
Nov 10, 2004 06:08 PM
92JDMSiR
Apr 13, 2002 02:20 PM
