Question about setting timing
Old Dec 16, 2008 | 07:32 AM
ksphar's Avatar
Default Question about setting timing
Just bought a 90 hatch with a ZC block and Z6 head. Doesn't seem to have much pull below 3k, and i think it might be a timing problem. Problem is, it is missing the lower timing belt cover. I plan on getting a new one, but is there any way to check the timing with that cover missing? Isn't the timing pointer on the belt cover?
Old Dec 16, 2008 | 05:04 PM
ef 991red's Avatar
just make sure that u cam sprocket is ponting tdc and in the crank u may get a mark in ur oil pump, not so sure of this, or simply get a manual or go to autozone website and look for the manual of both engines and ull find an answer.
Old Dec 16, 2008 | 07:37 PM
acmoc's Avatar
advance 3 degrees also to increase kick
Dan in Japan
May 20, 2008 06:33 PM
fast4imports
Jul 26, 2007 10:18 PM
jakscivic
11
May 1, 2006 08:36 PM
T--Rex
Jul 4, 2004 04:18 PM
speedaccordinly24
Apr 21, 2003 08:10 AM
