Clutch ?
Old Dec 16, 2008 | 04:54 AM
Swaped_EF's Avatar
Default Clutch ?
So my LS swap is almost done, all i need to get is a Clutch should i go stock for now till i go LS/V-tec or should i just get a Stage 2 now while im already looking for clutchs? and what would be the best Clutch for my money?
Thanks guys
-Phil
Old Dec 16, 2008 | 08:21 AM
S2KFTW's Avatar
doing the clutch while the motor is out of the car is always a good idea, it's a million times easier I personally love ClutchMasters, their stage 3 will hold lots of power but still engage nicely and not chatter. I've owned both ACT and CM and I'll never buy another ACT clutch.
Old Dec 16, 2008 | 08:22 AM
Paul-R's Avatar
i say get the clutch now so you won't have to pull the tranny out once again .
Old Dec 16, 2008 | 08:29 AM
acmoc's Avatar
Yea, if the motors is out, it's plenty easier, I have an exedy oem clutch I bought as a kit that came with a race flywheel. Depending on how much power you have, you might not need a stage three.
Old Dec 16, 2008 | 08:42 AM
Swaped_EF's Avatar
Thanks guys, well my motor is stock right now im just goin to get the car to where i can drive it as a DD then im goin to go LS/V-tec for awhile and then im goin to go throw the motor and build it a lil then throw 8-12 lbs to it, how much power will a Stage 3 clutch hold up 2? thanks guys
Old Dec 17, 2008 | 05:07 AM
CRX Toad's Avatar
Lets start here first. What are you going to be using the car for? Blanket statements and assumptions we really have no clue about anything of your car.
Old Dec 17, 2008 | 08:33 AM
Swaped_EF's Avatar
Im just goin to use it as a DD and sometimes stomp the **** out of some DSMs. The motor will be Simi Built and 10-15 lbs of boost
Old Dec 17, 2008 | 08:46 AM
jhammond_82's Avatar
Reject Papi
and 10-15 lbs. of boost
make up your mind, lol, jk. anyway look at the differences in clutches they usually say how much power they will hold. amount of boost has nothing to do with the power the clutch can handle. 8-15 lbs. of boost does not determine how much power an ls/vtec will make. in other words, set a hp. goal, and then decide on a clutch tha will handle the power that you are expecting to make.
Old Dec 17, 2008 | 10:16 AM
crxfreak1117's Avatar
lsd makes a good clutch i have one in my crx and havent had a problem yet and its 400hp and there dirt cheap also here is the link to there site
www.lsdmotorsports.com
Old Dec 17, 2008 | 03:47 PM
Swaped_EF's Avatar
Thanks Guys ^^^^
Old Dec 17, 2008 | 03:56 PM
sirtef9's Avatar
Nice hatch on your avatar:-)
s2k_8582
Honda S2000
Jul 20, 2011 12:09 AM
94-integra-ls
Oct 29, 2009 05:34 PM
93CivNewB18
Jan 8, 2009 02:06 PM
b20gsr10.9
Dec 14, 2007 02:24 PM
cheyennerex
May 26, 2003 09:13 PM
