o2 sensor which wire for hooking up autometer a/f gauge for obd2
Old Aug 3, 2002 | 01:45 PM
Ignitecivic's Avatar
Default o2 sensor which wire for hooking up autometer a/f gauge for obd2
I have a obd2 integra and was wondering which wire would it be on the o2 sensor to install the autometer a/f gauge thanks. My o2 sensor from the cat at the bottom is 2 black 1 green and 1 white which one is it? I'm assuming its the green one?
Old Aug 3, 2002 | 01:57 PM
louder160's Avatar
Default Re: o2 sensor which wire for hooking up autometer a/f gauge for obd2 (Ignitecivic)
ok your white is your sensor wire and your green is yor nominal ground. the two black wires take care of you temp.
Old Aug 20, 2002 | 06:37 PM
MikeMAN's Avatar
Default Re: o2 sensor which wire for hooking up autometer a/f gauge for obd2 (louder160)
you can either use that one, or off the ECU's wiring harness, there is on the furthest clip to the right, a white wire with a red stripe.
good luck!,
mike
dc4drewH
Aug 17, 2006 09:02 AM
PearlWhiteAccord
Dec 31, 2005 01:40 PM
racinskittle
Jul 6, 2003 10:42 PM
Ignitecivic
Aug 3, 2002 05:10 PM
dnt94civic
May 22, 2002 04:54 AM
