Help no start... 98 civic cx with gsr swap
Old Dec 15, 2008 | 08:10 PM
silentbeatz's Avatar
Default Help no start... 98 civic cx with gsr swap
how the problem started: i let my friend borrow my obd1 ecu so he can get his referee stickers. he probably had the ecu for 3-4 months since the ref closed down for a couple of months.... so my friend says he got his stickers and that he'll give the ecu back. i take off my ecu in the morning and drive my other car to work. my friend goes to work and we swap ecus. (my friend drove to my work using my ecu) so i hook my ecu back up a few days later and the car doesn't start... my obd2 to obd1 jumper harness is pretty messed up from disconnecting and connecting multiple times, so i thought that that was the problem. i pick up my obd2 ecu and remove the obd1 ecu, thinking that would fix the problem, but the car still did not start. the fuel pump doesn't prime when i try to start the car. what problems can cause my car not to start... let me know. thanks in advance.
Old Dec 15, 2008 | 08:18 PM
iamthefollower's Avatar
have you checked your main relay?
Old Dec 15, 2008 | 08:31 PM
i haven't checked anything since its been raining the last few days, and i work during the day so by the time i can work on the car, the sun's down and the rain doesnt help.
Old Dec 15, 2008 | 08:38 PM
I had a problem with my fuel pump not priming also about 2 wks ago.. I changed my main relay and it cuts on everytime. Also check your fuses and such, because your ecu fuse could be blown or one of the fuses under the dash.
Old Dec 15, 2008 | 08:47 PM
raidacaipo's Avatar
main relay.. check passenger side.. open the door and its on the side of the dash panel. its a square black box
Old Dec 16, 2008 | 09:44 AM
so it's probably just a coincidence that i swapped ecus and the car won't start?
mickey b16
Jul 27, 2009 10:41 AM
DeviousCTR
14
May 4, 2006 03:28 AM
tranceologist
Aug 28, 2005 05:05 PM
integra-modder
Mar 22, 2004 06:22 PM
743power
Aug 17, 2002 02:44 PM
