flywheel movement
Old Aug 3, 2002 | 01:24 PM
lilcasino's Avatar
Default flywheel movement
Just a little background: Car wouldn't start on back from Atlantic City. Push started it and drove it back to Maine(8 hrs) Problem is starter is making spinning/wizzing sound but won't engage flywheel. Have tried 3 different starters.
Today:
As per request of a couple of people on my car not starting I took the start off and inspected the teeth on the flywheel. All the teeth on the flywheel are good. However, I can move the flywheel in and out about 1/8 making it chatter. Is this a problem? I still have no idea why my car doesn't start. Any idea would be helpful.
Old Aug 3, 2002 | 06:50 PM
Kamin's Avatar
Default Re: flywheel movement (lilcasino)
you can move the flywheel in and out through the starter hole?
thats NOT GOOD
Old Aug 4, 2002 | 03:04 AM
Lei Siew Long's Avatar
Default Re: flywheel movement (KAMiN)
yes, there shouldn't be any play with the starter
Old Aug 4, 2002 | 03:19 AM
lilcasino's Avatar
Yes I can move the flywheel in and out via the starter hole. What would cause the flywheel to do that?
Old Aug 4, 2002 | 07:12 AM
non-VTEC's Avatar
the flywheel starter ring gear separated from the flywheel.........that's not good........time to replace the flywheel!
Old Aug 4, 2002 | 08:25 AM
lilcasino's Avatar
Default Re: flywheel movement (non-VTEC)
Would this make the car un-drivable? (I push started it and drove it 8 hrs) How could this happen? Also, I already have a comptech flywheel ready to go. I had a feeling it was something to do with the flywheel.
wakaranai
17
Sep 14, 2016 07:02 PM
b16ej8jdm
Apr 3, 2010 11:41 PM
94si94cx
Aug 5, 2003 06:56 PM
MrBui
Dec 23, 2002 10:29 AM
lilcasino
Aug 4, 2002 12:52 AM
