d16z6head poerted by RLZ 3 middle rod caps wore
yah yah i misspelled ported lol
well i took the motor aprat today to start the rebuild and found the cam and the 3 middle cam caps were wore way out of spec..
so zex 59300 cam is screwed along with my head that i ave a large amount of money in..
could i get a new rocker assembly weld the caps on the head and align hone the head... does anyone do this?>
why would you weld the caps to the head? You can have the cam caps/head align honed if that's what your asking... It's not cheap though and hard to find people who do it, about $300 last i saw, i have also heard of people machine the cam cap and insert a bearing in there...
depends on how mangled it is, maybe there is enough to take it off of the cap.
you can also have a bearing machined, but is all this worth getting another head done? you have to outweigh costs involved. with all that you may have a bandaided head that for a few bucks more get another head done.
Your kinda making RLZ look bad if someone just briefly reads that title. The porting has nothing to do with those cam caps wearing. Its the cam and springs that have an effect on that type of thing.
Seem like the comp cam 59300 has been ruining alot of heads.Ive had the same problem that drove me krazy for 2 months regarding low oil pressure. I use the cam as a pull up bar. From what ive read they can re weld and align hone the cam journal. Iould suspect that is alot of $$ to spend on a d-series head.
