snap on vantage graphing meter v8.0
Will sell for 495 obo. or trade for bosch 1000's + cash and pfab intercooler piping for s2000.
Up for sale is a used snap on vantage graphing meter, comes with 2 leads and v8.0 software, through 2005. Software came out in 06. Great for graphing out solenoids, amperage, can use with low amps clamp etc. this was used by me at an independent shop and at an acura dealership. i have no use now that i use a fluke88 and honda tools. in great working condition, screen is ok.just has fingerprints on the casing. very useful and can help with your shop prouctivity.
Snap-on Vantage Power Graphing Meter
The Snap-on Vantage Power Graphing Meter is a component-testing powerhouse that combines a graphing digital multimeter with a diagnostic database. It's like having access to a complete library of shop manuals for testing engine-management components, transmission sensors and components, and ABS systems.
Snap-on Vantage Features:
Includes Vantage Version 6.0 memory card. Learn More
Vantage has an automotive diagnostic database that covers virtually all electronic-controlled components for all domestic vehicles as well as most Asian and many European.
Vantage is automatically configured for vehicle and component-specific tests.
Vantage displays vehicle and component test-related tips including; on-screen connector drawings with pinouts and wire color information, component locator, known good waveforms, common failures and faults, updates, recalls, and descriptions of normal component operations.
Graph mode allows viewing of any meter reading as a histograph (over time).
Super sensitive glitch circuitry captures Min/Max readings down to 300 microsecond spikes.
Vantage features the same simple point-and-click operation as the MT2500 Scanner.
Vantage software is fully updateable, protection against obsolescence.
Vantage is capable of storing up to five single screens or two dual screens. In addition to screen storage, each screen in a movie review can be printed or downloaded to Snap-Link.
Snap-on Vantage Diagnostic Database:
The Snap-on Vantage Power Graphing Meter gives onscreen information for sensor, actuator, and control signal testing that is specific to the vehicle manufacturer and system. Depending upon the component selected, the test information includes:
A description of normal component operation
Component test-related tips, such as, common failures or faults, updates and recalls, and uncommon difficulties when testing or replacing the selected component..
On-screen diagrams of the component connector with pinouts, wire color information, and location.
A list of component-specific tests. For example, crankshaft position sensor tests may include a frequency test, an AC voltage test, a resistance test, an out-of-range test, and also a signature test. Signature tests allow you to compare the wave form signature of the component you are testing to a known-good waveform signature from the Snap-on Vantage Power Graphing Meter database. The Snap-on Vantage Power Graphing Meter has an extensive database of know-good waveforms.
With Vantage, tests are listed in the order that they are most commonly used and when you select a test, the Vantage automatically sets up the multimeter and displays test-specific information for the selected component. Vantage also has an on-screen Component Locator to help you by indicating the best test location and gives you special notes needed to locate and test components.
Snap-on Vantage Test Connections and Capabilities:
The Snap-on Vantage Power Graphing Meter has connections for four measurement channels and a serial printer. Two of the measurement channels are accessible through a single 9-pin mini-DIN connector for transducer connection. Transducer power is supplied by the Snap-on Vantage Power Graphing Meter.
Depending upon the selected channel, the Snap-on Vantage Power Graphing Meter can read;
DC voltage
AC voltage
DC current
Frequency Resistance (ohms)
Pulse-width and duty cycle
Injector on time (milliseconds)
In addition, selections are available for measuring diode voltage drop and continuity. Plus, Snap-on Vantage Power Graphing Meter is powered by two standard D-cell alkaline batteries and protected by a standard automotive fuse. Snap-on Vantage Power Graphing Meter battery life is more than 15-times that of most lab scopes. Definitely, everything you need, when you need it.
DC voltage
AC voltage
DC current
DC voltage
AC voltage
DC current
DC voltage
AC voltage
DC current
please email with contact info email to biglug63@msn.com thank Tim W
