radar detector
Old Nov 15, 2005 | 08:45 PM
Devo94ac's Avatar
Default radar detector
what does the codes really mean?
k ka and x
Old Nov 15, 2005 | 09:01 PM
romoracing's Avatar
Default Re: radar detector (Devo94ac)
K-Band
The most frequently used radar frequency band: 24.05 - 24.25 GHz. K-band made its appearance in 1978. The first K-band hand-held radar guns could only be used from a stationary position. Later, a "pulsed" version was introduced that could be used from a stationary or moving vehicle.
K-band radar waves have a relatively small wavelength. At the power level found in police radar guns, K-band has an effective clocking range of about 1/4 mile. Depending upon terrain (around a corner, over a hill, etc.), K-band waves can be detected from a range of 1/4 mile to 2 miles.
Ka-Band
In 1987 the FCC allocated a frequency on yet another band, Ka, for police radar use. Ka-Band incorporates Ka-band, Ka Wide-Band, and Ka Super Wide-Band. With Ka came the introduction of photo radar (also known as "photo-cop"). The photo-cop system works at 34.3 GHz and combines a Ka-band radar gun with an automated camera (see Photo Radar below).
The FCC later expanded Ka-band radar use to a range of 34.2 to 35.2 GHz. This became known as Ka Wide-Band.
The introduction of the "stalker" radar gun raised the stakes in the detection game. Unlike all previous guns, the Stalker can be FCC licensed for any frequency in the Ka-band between 33.4 GHz to 36.0 GHz, and so cannot be picked up by detectors designed only for X, K, and photo radar. Stalker guns are being used in more than half the country.
In response, manufacturers have developed detectors with "Super wide-band" technology that sweeps all of the Ka-band allocated to radar, as well as providing continued protection against X, K, and photo radar.
X-Band
The first frequency band allocated for police radar: 10.5 - 10.55 GHz. Dating from the 1950s, X-band radar is the easiest to detect because of its lower frequency and higher power output. Depending on terrain, temperature and humidity, X-band radar can be detected from a distance of 2 to 4 miles, yet it can only take accurate readings of speed from a distance of 1/2 mile or less.
Unfortunately, police radar is not the only source of X-band signals. Garage door openers, microwave intrusion alarms, microwave towers, and other high-tech equipment can fool a radar detector into giving off an X-band alert. Filters and redundant sampling are used to combat this "falsing."
93_teg_CT
Oct 11, 2005 06:05 PM
