If i have a type r ecu do i need a resistor box for my injectors..????
If i use the type r ecu do i still need the resistor box for the injectors..??? And witch resistor box do i use and how do i split the wires...?? Please help thanks...
what the ecu got to do with a resistor box?
check your injectors with a multimeter if it reads 2-3 ohm's you will need a resistor box if it reads 10 ohm's or higher you dont need a resistor box
look in the 92-00 civic forums and click on the FAQ'S for wiring info
blackntegra
Oct 29, 2006 11:49 PM
