96 Accord wiper problem
Old Dec 15, 2008 | 11:49 AM
69GTOby's Avatar
Default 96 Accord wiper problem
The windshield wipers act weird on my 96 Accord. When they are on a fast setting, the wipers will go all the way to the edge of the windshield trim, and are very noisy. But, when they are on a slow setting, and the windshield isn't that wet, they will go to about 5 inches away from the edge of the windshield. Also, when standing outside the car with the wipers in the park position, you can pull them up about 3 inches of travel. Is there something loose or worn out, or what?
Old Dec 16, 2008 | 06:33 PM
waciii's Avatar
I'd like to know the answer to this too. My 92 EX driver side wiper seems to overshoot by about that much in both directions.
Old Dec 16, 2008 | 06:50 PM
69GTOby's Avatar
Isn't it annoying!? Im glad Im not the only one with this problem. Lol I wish someone could lend some advice on this topic.
Old Dec 16, 2008 | 06:54 PM
Mr Yamada's Avatar
There are nylon bushings in the linkage that can wear out, and sometimes the bushing pops out of the rod ends.
I would first suggest that you be sure the wiper is tight on the post. You can flip up the bottom part of the wiper arm to get to the nut.
It isn't a fun job removing the plastic cowling that covers the wiper linkage, and many times the plastic clips will break. The rubber molding is also held on with small clips.
http://www.hondaautomotiveparts.com/
Old Dec 16, 2008 | 07:06 PM
redbull-1's Avatar
Here is a link to Autozone's repair guide that might help too:
http://www.autozone.com/addVehicleId...00c1528003a335
Old Dec 18, 2008 | 08:39 AM
69GTOby's Avatar
Awesome guys. Thanks. Ill look into this in the next couple days.
Old Dec 27, 2008 | 11:38 AM
Cactus's Avatar
Default Re: 96 Accord wiper problem
I just took the whole thing apart today but the 2 separate places the wire go into the motor stumped me. You can take the top off where the gears are but I couldn't get to the wires on the bottom. Since you can't get the wires off you can't pull the whole assembly out....WTF?
Old Dec 27, 2008 | 11:49 AM
P_Adams's Avatar
It would seem that the drive link from the motor to the Right Side Wiper Pivot may have broken at the ball link. Refer #12
If you can move both wiper arms together by grabbing just one, that tells me that the cross link #11 is secure - the problem is most likely #12, the arm which links the drive motor to the right pivot bellcrank.
P
Old Dec 27, 2008 | 12:00 PM
Cactus's Avatar
I wanted to pull the whole assembly out to check everything over but the wires stopped the party. Any suggestions? I am going to go get all new clips at Honda this week so when i pull it apart again it will be easier to reassemble. There is a little cross brace on top of the cowl that also makes getting the assembly out much harder.
Old Dec 27, 2008 | 04:39 PM
DrRuss's Avatar
As I recall the bushings are not available separately. I think you will need to get the whole link with two new end busings from the dealer. I had the same problem a while back. If you call the dealer the numbers in the figure won't help you will need to tell them what the link that you need connects to in order to get the correct one.
Good luck.
Old Dec 27, 2008 | 08:08 PM
P_Adams's Avatar
Good luck.
True, the link sockets are not serviced seperately.
The illustration I supplied was direct from the Honda Parts catalog.
Ironically, it's for the 1996/97 Accord (all models) so calling out a number with a reference to that page will get you the correct piece.
If there is a question; right click on the illustration; save it in your "My Pic's" folder, print it out and take it to your dealer for reference.
P
Old Dec 28, 2008 | 10:47 AM
Cactus's Avatar
I still want to know how to get this whole assembly out? The wires are killing me.....
Old Dec 28, 2008 | 11:17 AM
redbull-1's Avatar
To get the wires out, unplug the connector, then pull out the whole motor assembly after the mounting bolts are remove.
Old Dec 28, 2008 | 01:08 PM
Cactus's Avatar
Thanks. I was looking at it again and realized that is what i have to do. Can I buy that whole assembly minus the motor? I'll just replace everything if it is not too expensive.
Old Dec 28, 2008 | 01:10 PM
redbull-1's Avatar
Yes, you can buy the whole assembly minus the motor.
Old Dec 28, 2008 | 03:51 PM
Cactus's Avatar
Any idea of the cost? Where is the best place to order Honda parts online? I have a Porsche 911 as well and I order all my parts from a dealer in Oregon because they are sooo much cheaper than my local stealer. Not just a little but a pretty significant difference in prices.
Old Dec 28, 2008 | 07:08 PM
P_Adams's Avatar
156.00$ USD + Shipping from Majestic Honda (#10)
http://www.hondaautomotiveparts.com/...NDSHIELD+WIPER
That's cheaper than what most dealers would charge Wholesale accounts.
The only other options are used (recycled) or EBay (questionable)
P
Old Dec 29, 2008 | 02:22 AM
Cactus's Avatar
P
Holy crap P Adams that's quite a list you compiled! Thanks so much for all the info.....will update when I get it squared away.
Old Nov 5, 2009 | 06:35 PM
Cactus's Avatar
P
So I finally got around to this project and ordered the arms #11 and #12 in the illustration. Anyone know how these come apart? I haven't really tried it yet because the parts haven't come in yet.
Old Nov 6, 2009 | 02:19 PM
Cactus's Avatar
Anyone? P Adams????
Old Nov 6, 2009 | 06:28 PM
HonBeer's Avatar
why would you run the wipers dry?
Wrens
Jun 10, 2015 11:48 AM
ejmatzell
Mar 28, 2007 06:43 PM
hungtat
Feb 19, 2007 10:19 AM
Findingo
Aug 29, 2005 06:53 PM
badnan
Nov 24, 2002 04:37 AM
