94 honda accord turbo f22?
Old Dec 15, 2008 | 06:52 AM
mr.skinner85's Avatar
Icon2 94 honda accord turbo f22?
i want some advice on going turbo with my 94 acoord automatic ? f22b1 help me out
Old Dec 15, 2008 | 07:29 AM
GhostAccord's Avatar
Off the hop your Automatic will not like you boosting the engine at all. I would suggest you look into a 5speed swap first off.
Then you will need a to decide what your end goal is for this project?
Is this strictly a daily driver, DD and some track usage or strictly track?
How much power are you looking to gain?
What is your budget?
After you have come to a decision on these factors you can start looking into what type of chassis preparations (brakes & suspension) and turbo gear you will require to get you there.
Check out the Forced induction forum and it's FAQs you may find some very interesting articles already listed in there.
Cheers and happy reading.
Old Dec 15, 2008 | 07:54 AM
Brad_and_the_acc's Avatar
X2 The auto trans will start to slip rather fast if you add boost. I would most likely bet your trans allready slips with heavy acceleration. The clutch converter solinoid doesnt seem to last long with much spirited driving, let alone boost.
Other than what GHOST has stated RESEARCH and KNOW HOW is the key to any forced induction build
Old Dec 15, 2008 | 11:08 PM
erk89's Avatar
Twin turbo it!!11!!!
Old Dec 16, 2008 | 12:14 AM
jwicecold's Avatar
Ive decided to turbo my f22 VTEC!! But I have a 5 speed.. Im gonna build the head first off.. Cam shaft, cam, valves,injectors then add need pistons and rods.. Sleeve it then Im goin with T3/T4 turbo.. Makin mine a quick daily driver!!! runnin 8-10psi.. No more.
Old Dec 16, 2008 | 03:14 AM
Why are you planning to sleeve it?
Unless you are planning on going with 87mm bore pistons, or larger, there is no need to sleeve the F22. The stock iron sleeves should be able to handle 8-10 psi with 85-86mm pistons.
Old Dec 16, 2008 | 07:20 AM
im looking to make about 200 to 250hp and yes it is a Daily Driver , my buget is $1000
Old Dec 16, 2008 | 07:24 AM
yes im not tryin to go no high than 8-10 psi
Old Dec 16, 2008 | 07:36 AM
AK_CRX's Avatar
with that last bit, I should say this... Cheap, Fast, Reliable (Choose two). If this is your daily driver, and you've only got $1,000 to burn, it might not be the best time for this build. Even if you did the build with 100% ebay meow parts you'd be on the edge of your budget and wouldn't even have tuning, and that stuff breaks frequently. I would take that $1,000 and use it toward converting over to a manual trans, with a strong clutch. I'd never ever ever throw a turbo on an auto honda... F that, auto trannys have enough problems handling factory hp, especially your particular year/make/model. It'd be great to find an H22 m/t for your car, considering how much better the gearing is.
Old Dec 16, 2008 | 11:28 AM
my buget is $1000
Even the thought of a turbo kit or a one off turbo setup is expensive. You are already over budget. lol.
Just go with "bolt-ons" I/H/E, and do some research on turbo setups and how they work. In a few years/months whatever it may be you can and will have the knowledge to do your turbo setup.
2171USMC
May 31, 2018 01:40 PM
Kristopherliam
Feb 14, 2014 10:13 AM
Hondaman91
May 8, 2013 10:56 PM
94accord25
Feb 9, 2010 03:18 AM
kpoe18
Feb 5, 2007 08:54 AM
