kyb agx adjustment question
Old Dec 14, 2008 | 08:55 PM
BAYxlude88's Avatar
Default kyb agx adjustment question
Wsup.I just got my shocks installed on my lude.I wasn't there when it was installed so I don't know how to adjust the rear suspension. where do I adjust the firmness of the rear shocks? Do I need to jack the car up or something? which way do you turn the ****? for example if I the shocks are on 4 do I go counter clockwise to get to 1 or do I go clockwise?
thx.
Old Dec 14, 2008 | 10:20 PM
Kronn 98SH's Avatar
The very top of the strut tower has a numbered dial on it. It turns with the flat head screw driver that came with your struts. Turn the dial to the desired stiffness.
1 = lowest
4 = highest
Old Dec 15, 2008 | 12:26 AM
BAYxlude88's Avatar
cool,thanks.this can be access if remove the trunk lining right?does it matter which way I turn (clockwise or counter) the ****?
Old Dec 15, 2008 | 08:30 AM
OmarR's Avatar
I don't think the way you turn it matters if I remember correctly. You do need to make sure that you first push down then turn to the adjustment you want.
Old Dec 15, 2008 | 12:46 PM
twiztid00002's Avatar
i just ordered mine couple days ago
is the higher the number, the stiffer it gets?
liike 1 is the softess?
Old Dec 15, 2008 | 03:41 PM
Kronn 98SH's Avatar
Originally Posted by Kronn 98SH
The very top of the strut tower has a numbered dial on it. It turns with the flat head screw driver that came with your struts. Press down and turn the dial to the desired stiffness, clockwise or counter-clockwise.
1 = lowest/softest
4 = highest/stiffest
As for the trunk lining, there's no need to remove it. Just pull back the corner under each speaker (for a 5th gen).
95civicohyeah
May 10, 2008 10:12 PM
Frstyl838
Suspension & Brakes
Jan 23, 2008 12:13 PM
Unjockable
18
Apr 18, 2005 12:03 PM
FirstAdition1
Dec 2, 2003 06:46 PM
IntegraBoy04
Aug 19, 2003 12:20 PM
