Poor Mans TypeR Block, head, and trans cheap cheap cheap!!!**buy now**2000.00obo
I have a FRESH poor mans type r block, b16 head and 99-00si trans for sale in a package deal and i need it gone like yesturday...please make me an offer and if its not too much of a lowball i will take it. Im also more than willing to deliver or meet if your somewhat close to michigan so make me an offer....i will start this at 2000.00obo, im also willing to take some parts off to make it even cheaper. like i said I NEED THIS GONE ASAP!!!!
**BLOCK**
-GSR block w/ fresh bore
-brand new oem Type-R pistons w/wrist pins
-brand new oem Type-R rings
-jdm gsr rods reconditioned with brand new arp rod bolts
-brand new ACL race bearings (main&rods) w/thrush washers
-GSR crank knife edged and micro polished
-brand new oem Type-R oil pump
-brand new gsr water pump
-brand new lightend crank pulley
-all new gaskets, and seals(front and rear main)
-9lb flywheel
-brand new exedy stage 2 pucked clutch kit
-the whole bottom end was balanced and blue printed and i do have alot of the recipes for seals, machine work, ect.
**HEAD**
-b16 head with stock cams
-brand new oem valve seals
-brand new supertech black nitride flat faced valves
-head was hot tanked and pressure tested
-new valve cover gasket, intake mani gasket
-stock intake manifold complete with all sensor
-brand new benen fuel rail (gold)
-aem fuel pressure regulator
-b&m fuel pressure gauge with an fittings mounting it to the rail
-brand new throttle body gasket
-brand new ngk spark plugs
-distributer can be either obd1 or obd2
**TRANSMISSION**
99-00 Civic si trans with roughly 40k on it. It has all new oe honda trans fluid in it and has 0 problems, no grinds, no noises, and does not pop out of gear. The mount bolts stripped out so i tapped new bolt holes in it to replace the shallow and small bolts that honda uses.
**BLOCK**
-9lb flywheel
**HEAD**
**TRANSMISSION**
BLACKLIST138
Jan 17, 2009 01:49 PM
civicking99
Dec 12, 2008 05:24 AM
