Parting out an NB turbo miata set up...SO cal but I will ship
Old Dec 14, 2008 | 12:33 PM
89efDUSTY's Avatar
Default Parting out an NB turbo miata set up...SO cal but I will ship
Parting out my turbo set up. I am located in 91706 (Baldwin Park CA…home of In&out J) for pick up and my number is 626-404-3593. Please call/text me only if you are local or nationwide feel free to text me. Thanks.
HKS topside manifold with t2 outlet flange - Worked perfectly, has no cracks, breaks, nothing. I had this mated to my 99 head and it had no leaks what so ever with the stock gasket. I loved this piece and it never gave me any problems. Asking 240 shipped or 220 picked up.
HKS Downpipe - as you can see it has a 3 to 5 bolt conversion and fit on my t25 flawlessly. The EGR port on the down pipe was welded shut by a crappy exhaust welder so it looks like crap but functions great, I will also include a little sheet metal EGR intake side block off). Along with the manifold and a t25 this will mate up to a stock down pipe and exhaust. One of the bolts was broken inside the 3 bolt bottom flange. Asking 200 shipped with the 5 bolt transition piece of 180 picked up.
Will sell the manifold / down pipe for 400 shipped or 360 picked up.
Oil Tee with VDO sender - Oil tee that fit’s the miata’s block and has two side 1/8 NPT female openings. (One has a blocker the other is open in the picture) along with the opening for the sender in the back. I used a VDO sender, this sender has a special BSP transition fitting so it matches your stock one. This is the sender that is used to make your oil pressure gauge actually fictional. Asking 60 shipped or 50 picked up.
Stainless Oil Feed line - Used this with the tee above to go over the valve cover and mount into the top of my t25. Both ends are 1/8 NPT female. Asking 40 shipped or 35 dollars shipped..
Will sell the tee/sender/feed line for 80 shipped or 70 picked up.
Flyin Miata Voodoo box - works perfect and I cut out the top so you can tune on the go instead of unscrewing it. I am including 5.5 feet of vacuum line that fits its tiny nipple….mmm I <3 tiny nipples. Asking 260 shipped or 250 picked up.
AEM UEGO - SOLD
Bosch BOV - Purchased from an Audi dealer approximately 4 months ago. Asking 50 shipped or 40 picked up. Including little transition piece I used as well.
Autometer pro-comp ultra light Boost gauge - SOLD
Intercooler with mounting brackets that fit NB - I used this Intercooler on my 99 and it fit perfectly center in the mouth (28x7inches with 2.5 openings). I removed the air grit plastic thing, and it bolted up into stock mounting holes, one was the baby teeth and I forgot the other one, but its there. I didn’t move the brackets so you can see exactly where it fits when you mount it. Asking 80 shipped or 60 picked up.
Here it is mounted.
8 psi wastegate - This wastegate was shortened and has a bracket with one bolt hole on it. I used it with my t25 and it worked great for my clocking position. Asking 40 shipped or 30 picked up.
T25 ar.86 exhaust turbine - t25 turbine with t2 inlet flange, integral wastegate flapper, and 5 bolt outlet flange. Asking 50 shipped or 35 picked up.
SR20 T25 two bolt compressor inlet flange/elbow - Little 2.5 compressor inlet flange I used asking 40 shipped and 30 picked up.
89efDUSTY's Avatar
Some stuff will work with hondas
Old Dec 14, 2008 | 12:44 PM
89efDUSTY's Avatar
SEXY!
Old Dec 15, 2008 | 06:53 AM
89efDUSTY's Avatar
TTT for flakers on all sites
Old Dec 15, 2008 | 07:44 AM
ekx4's Avatar
Old Dec 15, 2008 | 08:33 AM
r.wright's Avatar
hi ryan
Old Dec 15, 2008 | 11:38 AM
89efDUSTY's Avatar
Originally Posted by Opossum Jenkins
hi ryan
Hey Sexy...
Sad news A CHP officer died this morning on the 60 in Industry. Its crazy once you start the process it hits you. The guy who did the interview on all the news stories is a guy I have actually talked to for a while and was at my interview with me. RIP for him.
Old Dec 15, 2008 | 11:40 AM
89efDUSTY's Avatar
Turbine pending
Old Dec 16, 2008 | 06:58 AM
89efDUSTY's Avatar
Wow like 7 things were pending and one guy flaked...economy is so crappy!!!!!!!!!!!!
Old Dec 16, 2008 | 10:32 PM
r.wright's Avatar
rip man
Old Dec 17, 2008 | 06:50 AM
89efDUSTY's Avatar
rip man
poor guy was 29 and had 3 kids and one on the way...
STAY SAFE WHILE DRIVING IN THE RAIN SO CAL!
Wideband and boost gauge sold to SING
dragonjay006
Aug 6, 2007 03:25 PM
stackz
Welding / Fabrication
Feb 2, 2007 07:05 AM
KeyserSoze
40
Nov 27, 2005 10:21 PM
Neukin
Mar 1, 2005 09:07 PM
dan_w_82
Jan 18, 2005 09:29 AM
