Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
brand new car overheating?
Old Dec 14, 2008 | 10:49 AM
DcLs's Avatar
Default brand new car overheating?
posting for a friend. his 06 si coupe recently overheat while driving on home. the car is brand new when he bought it and now has only 11k on the clock. engine light shows up too. anyone know why its overheating?
Old Dec 14, 2008 | 10:51 AM
FijiBlueFG2's Avatar
Road House
Crusing around at redline? Miss an oil change?
Old Dec 14, 2008 | 10:53 AM
Paul-R's Avatar
it's because he doesn't know how to drive and he probably butt raped his head gasket already. if not that tell your friend to check the antifreeze and check on the bottom of the radiator to see if there any leaks . if not check water pump to see if that leaks other then that it shouldnt be leaking .... new car "DO NOT HALL AZZ IT FOR THE FIRST 20K"
Old Dec 14, 2008 | 11:04 AM
DcLs's Avatar
oil was pretty low but not empty. gonna bring to shop to check it out thanks guys
Old Dec 14, 2008 | 11:21 AM
wilham320's Avatar
make sure to fill all the fluids up before you take it in...
Old Dec 14, 2008 | 01:03 PM
K5^'s Avatar
K5^
Brand New
x2.
Any signs of leakage anywhere?
Old Dec 14, 2008 | 01:08 PM
SIVIC 3's Avatar
its under warranty right? just bring to the dealer, your question and circumstance are too vague for an answer here on the board. kthnxbye
Old Dec 14, 2008 | 05:59 PM
kartman5's Avatar
He may want to learn more about his car.
coolant level?
oil level?
does radiator fan kick in?
does he watch his temperature gauge?
how does he drive it?
how does he maintain his car?
how was the car maintained before he got it, since it's an 06?
did he continue to drive it after it overheated?
A well maintained care shouldn't overheat if drivien and taken care of, anyway good luck.
Old Dec 14, 2008 | 08:39 PM
DcLs's Avatar
coolant level?
oil level?
everything is in good condition. i think its the way he drove it since it a brand new car.
Old Dec 14, 2008 | 08:49 PM
E.Honda's Avatar
Missing an oil change will not cause the car to run hot.
You can't cruise at redline either.
Cruising is about 5-10 MPH.
Old Dec 14, 2008 | 08:50 PM
E.Honda's Avatar
You should be able to drive the car at redline for an hour without overheating......Unless he is in the desert right now I would suggest it is something else.
Old Dec 15, 2008 | 06:22 AM
builthatch's Avatar
MiG-21 superfan
bring it the dealership. it's under warranty. don't touch a thing. get it to a preferred dealer ASAP. if your friend wears his had sideways, tell him to straighten it before he goes into the service department.
end of story.
if it's got a turbo, or supercharger, let us know...
Old Dec 15, 2008 | 01:42 PM
2008fijibluesi's Avatar
Excuse me, but what the hell are you talking about? I agree, you could not cruise at redline, but it is definitely not 5-10 mph. I'd say it's just a moderate, steady speed. Cruise control! Enough said. I'll bring out the dictionary if I have to.
Missing an oil change could cause a car to run hot. If the thing is 2+ years old and only has 11k miles on it, it has sat for some time, which isn't great for a car. Beating on it the only time you do drive it and missing an oil change could potentially burn oil, and cause more friction, thus causing heat.
Old Dec 15, 2008 | 04:12 PM
DcLs's Avatar
okay so we went to the dealer and we found the problem. the belt on the water pump was too tight. everything else was good had it replace and good to go thanks guy
Old Dec 15, 2008 | 04:40 PM
R Legend's Avatar
You did the right thing and got it taken care of. Good to know.
racerx159
Jul 1, 2005 12:44 PM
VINtegra90
Apr 11, 2005 11:11 AM
infamousALLMTR
Sep 21, 2002 11:26 PM
