96 Accord ECU Location
P
has anyone been removing their ecu's as a form of security or to prevent theft since no ecu equals no start. I have been contemplating this.
sorry for bumping an old thread
It's much akin to unplugging your Pentium CPU everytime you left your room. How long would it be before those pins got damaged?
It would be far easier to hide a starter interupt switch somewhere, like behind the ashtray
.P
http://www.helmarparts.com/product_p/20151-00.htm
and interupt the starter circuit at:
Clutch override switch (Manual Transmissions) or
Neutral safety Switch (Automatics)
P
I take key switches like this sample:
P
P
Picture the switch with two really long 14 gauge wires connected to it.
One end of each are attached afixed to the switch, the other ends are just... out there.
Pick your target (Manual Transmission as an example), the clutch override switch. Pick the wire which connects to the switch which is energized by the Ignition switch start position (test light or multimeter required).
Giving yourself enough room (slack), cut this wire, strip back a length of insulation and attach one wire from the switch to one end of the cut wire, and attach the other wire to the other end of the cut wire.
Make sure that you have tight connections and that they are properly insulated. I soulder them and use heat shrink tubing.
Mount the switch anywhere you can think of.
dvp95
Jul 9, 2011 05:29 PM
