ecu for d16z6
Old Dec 14, 2008 | 10:29 AM
the_dxB16's Avatar
Default ecu for d16z6
is the p28 the right ecu for the d16z6 i have it on but the fuel pump wont come on.
Old Dec 14, 2008 | 10:36 AM
TeamRPM_ZC's Avatar
check your fuel pump relay, got a used one from the junkyard and it works now, and correct ecu
Old Dec 14, 2008 | 10:39 AM
Syndacate's Avatar
Yes, the correct ECU for the D16Z6 is the P28.
As for your fuel pump, check A) Fuel pump relay, B) Fuel pump wires, C) Fuel pump.
Do you have power at the fuel pump?
If yes, and it's 12v DC - then you have a bad pump or a bad pump ground.
If no, move up front, check to make sure there's power coming out of the fuel pump relay, if yes, then it's a bad wire somewhere to the back, if no, check to make sure there's power going into the relay, if yes, it's a bad pump relay, if no, then check the wire going from the ECU to the fuel pump relay. If there's power coming out of the correct pinout on the ECU for the fuel pump relay, you missed something, or you have a bad ground somewhere.
Hope that general work-up helps you a bit.
Old Dec 14, 2008 | 11:18 AM
xXvtec5kXx's Avatar
also check ur fuel pump FUSE under the dash...i had one blown on me while on the freeway!...good thing i had an extra fuse in my car....
Old Dec 14, 2008 | 11:21 AM
the_dxB16's Avatar
ok where is the relay at and the check engine light doesnt come when i turn the car on. so i think there is no power going to it.
Old Dec 15, 2008 | 08:06 AM
Syndacate's Avatar
Is there any power going to your car? Can you listen to the radio while the ignition is set to "on?"
Old Dec 16, 2008 | 06:56 AM
the_dxB16's Avatar
i got it it was the ground to the battery wire.
girlcrx
Mar 9, 2014 06:04 PM
zippakilla
Feb 6, 2009 04:01 AM
tegdude227
Jan 31, 2009 03:59 PM
bc matt
Apr 2, 2005 01:17 PM
partyguy1516
Dec 28, 2003 05:14 PM
