Leaky fuel injectors.. fuel smell after starting
Old Dec 14, 2008 | 09:01 AM
M3 Adjuster's Avatar
Default Leaky fuel injectors.. fuel smell after starting
My 1993 Accord EX 5 MT is hard to start, and once started has a great fuel odor in the cabin. This appears to be a leaky injector per other posts in the forum that I have read.
I am looking to either replace the injectors with another set by buying a set and then having them refurbed at a place like cruzin performance (a little cheaper than RC engineering) and then swapping them so I don't have the car down for awhile. I know that the Accord engine was used for several years, are there other models beyond 90-93 that have the same injectors? I found a set of injectors for a 94 Accord EX on for under $20 Ebay and want to make sure they will work.
Also, if new seals are needed, if anyone has a part # for the fuel injector seals that would be nice.
Old Dec 14, 2008 | 10:32 AM
blauenlanze's Avatar
Hey I've been looking at o-rings on injectors recently (I think seals and o-rings mean the same thing, I'm not sure though) and I've come upon this at Partsamerica. http://www.partsamerica.com/productd...Number=1580308
You could probably find it for cheaper on Amazon or something though. Not sure how many injectors it has rings for.
Old Dec 14, 2008 | 12:21 PM
P_Adams's Avatar
You've most likely at least one injector that's leaking down after the engine's off, causing a poor start in the morning. The Leaking 'O Rings are a coincidence, but related.
The O'Ring number's are: 16074-ZY3-000
The Injector Set Numbers are: 06164-P0A-000
P
Old Dec 14, 2008 | 05:49 PM
YeuEmMaiMai's Avatar
you can also get your injectors repair and flow matched for less than you can get them new in most cases
Mikes97Accord
Mar 11, 2016 08:03 AM
JDM_Acccord
Sep 22, 2007 05:36 PM
vtgearhead
Apr 29, 2007 09:57 PM
e jay one
Mar 26, 2007 03:58 PM
allmotor.net
Sep 27, 2004 11:57 AM
