Massive HONDA parts BLOWOUT
Old Dec 14, 2008 | 01:30 AM
Extradition's Avatar
Default Massive HONDA parts BLOWOUT
**Best offers being accepted as well, some prices are FIRM, shipping MAY be MORE**
BRAND NEW CUSCO LSD for B16/ITR - $800 (retails for $1300)
OBD2B 2000 P73 USDM ITR ECU (still has ignition immobilizers but can be removed) - $100
D-series Custom Turbo kit all new parts including: Tial style Wastegate, Greddy sandwich plate (allows oil lines to be ran without tapping block/head), HKS style BOV, XS engineering exhaust manifold, custom front mount intercooler, and Garrett turbo - $500
92-95 eg6 SiR spoiler (has small crack near long LED can easily be fixed) - $90
96-00 EX gauge cluster (auto and Manual available) - $60 auto/ $70 manual
4x100/4x114.3 SET OF FOUR: Maxxim Racing rims 18" with tires (still good) - $200
96-98 Rear tailights (COUPE) - $60
96-00 Power window TWEATERS (COUPE) - $40 both
90-91 OBD1 F22a Distributor - $50
96-00 Si stock struts and Neuspeed springs - $160
EG/DC MoMo Hub and EF MoMo Hub - $40
OBD1 P06 ECU (Manual and Automatic)- $45
OBD2a P2P ECU (VTEC and Manual tranny) - $50
OBD2a P2P ECU (VTEC and AUTO tranny) - $40
OBD2a LS ECU (automatic tranny) - $45
OBD1 P28 ECU (VTEC and Automatic) - $110
2004 RSX ECU (Base model and Automatic) - $100
B-series DH racing dual valvesprings and MOLY retainers - $180
92-96 Prelude EL gauge cluster with inverter and wiring harness - $120
H22a Vtec solenoid with pressure switch - $45
D-series Vtec solenoid with pressure switch - $30
B16a/GSR/ITR Vtec solenoid with pressure switch - $45
B-series throttle cables - $15 each
ONE LS rim with A cap (backside has slight bend in lip) - $30
GSR/ITR/B16 OEM fuel pressure regulator - $10
Stock GSR exhaust manifold with heatshield - $50
99-00 Si headlights OEM STANLEY - $100 pair
96-98 stock headlight OEM STANLEY - $40 each
DC/DB/EG/EH B-series mounts with manual tranny - $60
OBD1 stock P30 B16a JDM Intake manifold - $40
Sony Headunit (52watts x 4) with remote and harness - $100
B-series HYDRO shiftlinkage - $50
B18C JDM SiR-G GSR block (will come bare but with mains, mainbolts, girdle, and oil squirters). It needs a re-sleeve due to a bad piston BLOCK HAS NO HOLES - $200
OBD1 B16/GSR/LS injectors (240ccs) - $30
OBD1 B16/GSR IACV - $30
RS integra 40/40 Prop valve and 15/16ths brake Master cylinder (perfect rear disk upgrade for eg/eh/ej chasis) - $50 both, $30 each
Integra steeringwheel with stiching (similar to ITR) - $80 with Acura or Honda airbag, $40 without
92-95 Civic Stock airbag (GREY) - $30
Winshield wiper motor (92-00 civic) - $40
EG rear 1/4 panel glass (I have both sides) - $30 each
92-00 Civic gas tank with stock fuel pump and float - $80
96-00 civic driverside window MOTOR ONLY (roller gear is STRIPPED) - $20
4 door EK sedan doors (all are good except rear passenger). All glass is in perfect condition and all window regulators are in perfect condition (ALL FOUR) - make offers on parts needed
Stock EG driver door with no trim (CX/VX model) - $50
EG rear hatch glass with winshield wiper - $50
EG/EK manual tranny pedal assembly - $50
EK sedan stock exhaust includes piping, muffler, and CAT - $70
EK Power steering rack with tie rod ends and lines - $40
EK sedan stock manual mirrors - $30
Stock eg door panels - $50 for both, $30 each
D16z6 complete head with vtec solenoid, intake manifold, injectors, throttlebody, fuel rail, MAP sensor, D16y8 valvecover, headbolts, TPS sensor, and IACV - $100
D16z6 crankshaft (U should micropolish) - $40
D16z6 Oil Pan - $40
D16z6 alternator - $40
92-95 Civic manual tranny Ignition lock with tumbler and key - $50
Stock 96-00 Civic DX brake booster and master cylinder - $30
Stock 1998 D16y7 Non-vtec head with camshaft, complete internally no problems - $40
Stock EG sedan REAR door handles (KEYLESS) - $25
Stock EK front door handles (No locks) - $15
Stock EK sedan REAR door handles (KEYLESS) - $30
~~~~~~~~~~~~SOLD~~~~~~~~~~~~~~
GSR/B16/Type R stock sparkplug cover - $20 (SOLD one to 1990HF- 1 remaining)
2000 Civic Si trim bezel - SOLD TO FSUseminoleEM1
99-00 Si 40/40 prop valve and 7/8ths brake Master cylinder - SOLD TO Sheekdude
OBD1 B16a/GSR distributor -SOLD TO xtegb16x
OBD1 Si/EX VTEC wiring harness - SOLD TO xtegb16x
Integra driverside mount - SOLD TO xtegb16x
92-95 Si/EX Gauge cluster - SOLD TO xtegb16x
P06 ECU - SOLD TO xtegb16x
P06 ECU - SOLD TO JerseySiPOS
NRG quick release - SOLD to Racerdanny
88-91 OBD0 B16a DOHC Vtec Distributor - Sold to BlkDa9
92-95 OBD1 B18b Distributor - SOLD TO epicjkr8zero5
92-95 Civic VX model door - SOLD TO jjr
96-98 Civic DX engine harness - SOLD TO Mr. EM1
95 JDM GSR Oilpan - SOLD TO BoSox46GSr
99-00 B16a IACV - SOLD TO 2000blksi
99-00 B16a IACV - SOLD TO 88si
B-series Vehicle Speed sensor - SOLD TO Iron_Forrix
92-95 CIVIC HATCH/COUPE DOOR TRIM - SOLD TO SLO_EH2
OBD1 P28 ECU (VTEC and Manual) - SOLD TO Civic_Hatch
GSR fuelrail and OBD2 injectors - SOLD TO dog2525
Skunk2 Coilover springs and sleeves - SOLD TO 08rampage
VTEC pressure switch - SOLD TO underb00steg6
GSR shiftknob - SOLD TO CUTTERSPOOL
99-00 EM1 ebrake cables SOLD TO 94allmotor
OBD2A P2E ECU - SOLD TO justlook
B-series HYDRO throwout bearing and Pilot bearing - SOLD TO scspeed
Polished ITR 5x114.3 rims with S2000 H caps (no tires) - SOLD TO c1_sleeper
92-95 OBD1 D16z6 Distributor - SOLD TO crispy93
1996 LS Transmission - SOLD TO simpleteg3
1995 USDM GSR shortblock - SOLD TO simpleteg3
2 Firewall Mounting MAP sensors - SOLD TO MysticalMagnet
**Updates and pictures coming**
Old Dec 14, 2008 | 09:20 AM
TheJunBuilt's Avatar
pm sent.... item not listed ..
Old Dec 15, 2008 | 02:21 PM
Pm'd back.
Old Dec 18, 2008 | 03:43 PM
Mikeb353's Avatar
Sent you a pm
Old Dec 18, 2008 | 05:17 PM
eskimo10's Avatar
PM'd.
Old Dec 18, 2008 | 09:49 PM
1995Civic's Avatar
Pics of the NRG QR? Is it for an EG or what? Color? Gen 2.0 or 2.5?
Old Dec 18, 2008 | 10:43 PM
seek167's Avatar
pics of the 99-00 head lights
Old Dec 18, 2008 | 11:21 PM
iOn's Avatar
iOn
PM sent, bump
Old Dec 22, 2008 | 01:56 AM
Default Re: Massive HONDA parts BLOWOUT
PM'd and more updates.
Old Dec 22, 2008 | 02:03 PM
Up
Old Dec 22, 2008 | 04:06 PM
nrich's Avatar
pix of the headunit? will harness fit on eg?
Old Dec 23, 2008 | 12:15 AM
Need your email, if anyone needs pix just message me your email address and what item U're interested in.
Back up.
Old Dec 23, 2008 | 04:49 AM
G Rabbitt's Avatar
Also curious about quick realease...
Old Dec 25, 2008 | 12:12 AM
bump
Old Dec 25, 2008 | 11:48 AM
EFSedan#6's Avatar
damn, good stuff.
Old Dec 25, 2008 | 01:51 PM
neofreak's Avatar
pics of quick release and EF hub?
Old Dec 25, 2008 | 03:42 PM
thanks guys, the Quick release is pending sale, but I still have both the hubs. If you're interested in that, get at me.
Old Dec 26, 2008 | 03:07 AM
Up
Old Dec 26, 2008 | 11:48 AM
bump
Old Dec 26, 2008 | 10:21 PM
94_Civic_Hatch's Avatar
Still got the quick release? If so PM me
Old Dec 27, 2008 | 10:21 PM
geneeunit's Avatar
PM'ed..
Old Dec 28, 2008 | 02:16 AM
Quick release GONE, thanks for everyone's interest. MORE PARTS TO COME!
Old Dec 28, 2008 | 11:01 AM
EFSedan#6's Avatar
damn, those EG/EJ seats bolt into an EF??
Old Dec 28, 2008 | 04:26 PM
I think U could mount them up, but not all the holes would line up. In fact I picked up some ITR seats in a 1987 Mazda pickup at the junkyard one time (what a lucky find). I think shipping would KILL U.
Old Dec 29, 2008 | 12:53 PM
Up
