No heat!!!
Old Dec 13, 2008 | 10:17 PM
bLu92bUbbLe's Avatar
Default No heat!!!
last winter my heat was so hot i was ready to get a nose bleed riding around...i did a swap...put in a new thermostat and added lots of 50/50....**** is cold...i was told to bleed the system...tried that...heat is warm now...my question is...what is the correct way to bleed the system...i need my heat hot. Its too cold to b driving like this. HELP HELP HELP!!!
Old Dec 13, 2008 | 10:20 PM
niceprelude's Avatar
any leaks
Old Dec 13, 2008 | 10:24 PM
dropped_dime98's Avatar
When adding radiator fluid are you doing it with the car running and with the heat on full blast?
Old Dec 14, 2008 | 08:32 AM
Civic_07's Avatar
you can do it with the car running and keep on adding fluid...you should see all the air come out..
Old Dec 14, 2008 | 09:16 AM
jimmy o.'s Avatar
heater core could be blocked try blowin it out with some compressed air
Old Dec 14, 2008 | 05:52 PM
Originally Posted by niceprelude
any leaks
nope...no leaks...
yessir!
Old Dec 14, 2008 | 05:54 PM
when i do it...all i see is fluid running back out...with the car running...and the heat on full blast...still nothing...
Old Dec 14, 2008 | 06:09 PM
tigasin's Avatar
Icon3
^+1
Old Dec 15, 2008 | 05:44 AM
honda.lioness's Avatar
One of the critical steps is waiting for the fan to come on twice. This typically takes 40 minutes or more in U.S. winter temperatures.
The owner's manual has the procedure for bleeding. Or use http://www.autozone.com/shopping/rep...0615b5#hd1-1-3
Old Dec 15, 2008 | 05:56 AM
jeremyrocksursox's Avatar
we can always use our trusty helms manuel though
Old Dec 17, 2008 | 07:18 PM
iight thanks...
Bill Leland
Jun 12, 2014 02:29 PM
darkblackH2B
Dec 15, 2008 07:08 PM
ex_crxer
Apr 6, 2003 06:52 AM
brotherton16
Dec 5, 2002 07:18 PM
Ludester
Dec 3, 2002 03:50 PM
