99-00 Si cluster into 96-98 ek
Hey guys, I just ran into some problem with my si cluster. When I plug the si cluster into my car, the temp and gas gauge doesnt work. Can you guys help me out? Thanks
drounding or grounding? I mean shouldn't the 99-00 si cluster be a plug and play into a 96-98 ek hatch? Both of my gas and temp arent working. The Rpm gauge and mph is fine though.
EDIT: My fuel and temp gauge works when I put in my original DX instrument cluster. When I installed the si cluster, it doesnt work at all.
worst case scenario, take out the housing & swap face plates// i had that problem previously i just swapped them, they are basically the same thing just different face plates....g/l
nvm i figure out the problem. I swapped my Si Temp/Fuel gauge with my friend's EX Temp/Fuel gauge to test it out, and turns out that I need a new gauge! Well the Si temp/fuel gauge that is. Only 28 bucks from honda so ima just order it from there. Thanks for the help guys.
97_Ek
Mar 13, 2008 08:55 PM
GreddyCivic7
26
Apr 11, 2007 03:38 PM
137
10
Apr 22, 2004 12:58 PM
Mr Boston
Sep 6, 2003 10:00 AM
