Steering wheel noise
Old Dec 13, 2008 | 06:55 PM
niceprelude's Avatar
Default Steering wheel noise
just had this clicking noise,when the steering wheel is making turn.Please help
Old Dec 13, 2008 | 07:54 PM
need some answer
Old Dec 13, 2008 | 07:57 PM
Davus's Avatar
Your CV joint/axle is possibly damaged. Replacement costs about $60 to $70 for the part, or $150 for the part & labor. It is a DIY project if you'd so like.
Check your axles next time you're at the car, see if the boot is torn. If so, the lubricant within has been lost long ago, and you are very likely plagued with debris within the CV joint. It is easier, in most cases, to replace the entire axle assembly (for the particular side) than to just replace the damaged section.
Report back after you've looked under the car please. Also, hourly bump? >_>
Old Dec 13, 2008 | 08:04 PM
how to do it fix it
Old Dec 13, 2008 | 10:02 PM
how difficult to fix it and its the left side,do i have to replace both side
Solstic
Oct 6, 2013 11:06 PM
VTECdohcter
Feb 14, 2009 07:50 PM
rob[CB7]
Aug 2, 2008 08:28 AM
b18c-1
May 17, 2006 04:25 PM
yaced
15
Apr 5, 2006 10:02 AM
