98 4cyl. strange starting problem
HELP?
was backing it out of the garage and it stalled (cold engine) and wouldn't start again.
it will turn over like it wants to start. smells of gas. checked plugs and there is no spark.
the strange thing is...when i back off of the ignition, it does fire for one second but only
when i let off trying to start. crank sensor?
the distributor is fairly new though not oem.... no spark
coil problem?
took distr apart and is dry and clean. only about 5k on it. try replacing internals of distr?
NO Check engline light
coil problem?
I would suggest you get your VIN and call the dealer to see if the ignition switch recall has been done to your car.
The reason I'd suspect the ignition switch is because I've limped many of them into the shop holding the key just a little bit off the crank position to keep them running.
If it is not the ignition switch I would test the ECT temp sensor, if it shows the engine super cold, like -40F, then it will want to flood the engine on start up and you would smell gas and I would think that it is washing down the rings and getting fuel into the oil so it will smell of gas too, if it does then it will need changed right now.
Power for the distributor comes directly from the ignition switch, a bad ECT sensor does not care how warm your garage is, if it wants to go open circuit, then it will tell the computer that it is -40F and flood the engine. You seem to think that your problem is a no start, no spark issue though so lets go for that instead.
You will need help to turn the key and verify that you have no spark, are you saying that you did that already. If you have an old spark plug, cut the L off of the end so the spark has to jump as far as possible, leave your good plug in the engine while grounding this test plug to the top of the engine to look for spark or intermittent spark.
Elvis1977
Oct 29, 2018 10:08 AM
LSteggyguy
Jun 4, 2014 05:45 AM
josepagina
Aug 2, 2013 10:44 AM
