can i change this hub to a thinner one?
Old Dec 13, 2008 | 10:10 AM
DeyAinRdy4Ds's Avatar
Default can i change this hub to a thinner one?
by any chance....can i change this hub that sits on the rotor to a thinner one?
Old Dec 13, 2008 | 06:07 PM
RaysBoomBoomLude's Avatar
What? you want the hub to be shorter?
Possibly, but I dont think its a good idea.
You will more then likely run into clearance issues, like the rim and caliper, the castle nut and rim\hub.
Old Dec 13, 2008 | 08:12 PM
92bb2's Avatar
why would you want to???
And where are you expecting to find one?
Old Dec 13, 2008 | 09:57 PM
want one short enough to obviously clear the caliper...but its cuz i got some wheels with a +15 offset so they stick out past the fender some.....so basically i realized if the damn hub was a bit thinner, itd fit just the way i was going for.....i know its kinda odd...but..anyone ?
Old Dec 14, 2008 | 12:58 AM
ethereal2pt2's Avatar
it would have been a lot easier to find some wheels with more positive offset.. and +15 wtf? let's see these wheels.
Old Dec 14, 2008 | 12:32 PM
ya but they were the only available offset for the wheels n i really liked em so i jus figured id give it a try.......they didnt even have the right centerbore size n i jus got em bored out to the 64.1 from a 57.1 so theyd fit the hub....theyre not on yet....
heres the wheels
Old Dec 14, 2008 | 01:35 PM
Kronn 98SH's Avatar
adjust the wheel for the car, not the car for the wheel
Old Dec 14, 2008 | 01:47 PM
kinda too late for that lol
so anyone know if i could change out that hub...i dont see why it should be so difficult, but i wouldnt know where to even find the part?
Old Dec 14, 2008 | 03:43 PM
Giant_Bean's Avatar
You would have to replace a lot more than just the hub, the bearing is there, you would have to find rotors with a shorter hat, basically you shouldn't have bought wheels that you knew weren't going to fit right.
The only way I see that working is if you had a custom made knuckle that sat back farther, but still had provisions to mount all the factory components.
Old Dec 14, 2008 | 03:54 PM
i mean i was expectin em to stick out...it just turned out a lil bit more than i was expectin but i think it should look ok once the tires are on n stretched....i guess ill just see wen theyre on
Dy2*str33t-king
Honda CR-V & Element
Nov 9, 2016 11:21 PM
neiler3
Sep 12, 2006 10:37 PM
Blade_Irl
Nov 27, 2002 05:46 AM
Big Dog
Apr 30, 2002 03:33 PM
Todd00
Nov 26, 2001 09:36 PM
