tires rubbing!!
Old Dec 12, 2008 | 08:54 PM
ShawnbobHatch's Avatar
Default tires rubbing!!
i have 17's on my hatch, whenever i take turns pretty damn fast the body rubs the tires. it's starting to take some tear out of the outside of my right rear tire. my car does not sit low at all, sits about stock level. im planning on getting 15" rims but i want to lower it.... any suggestions??
Old Dec 12, 2008 | 09:00 PM
SOHC_4dr's Avatar
you already told us the solution to your problem. 15's and lower it
zuruk's Avatar
How wide are your tires? I run 205's on 7 inch width. No rubbing there
Old Dec 12, 2008 | 09:02 PM
IT'S ME DAVID's Avatar
NooB
if u have wear on the outside then your camber is off if its lowered they should be leaning in not out..get a camber kit and adjust it right and u should have no problems unless your tucking tires.
Old Dec 12, 2008 | 09:04 PM
Default g
i meant on the tread still just towards the outside of the tire. only one the right rear tire though none else.
Old Dec 12, 2008 | 09:07 PM
id say lowering it probably wouldnt help rubbing.
SOHC_4dr's Avatar
stop taking turns fast with the 17's!!! put the 15's on and get it aligned. or drop it some first(with the 15's), then get the camber kit and alignment
Old Dec 12, 2008 | 09:33 PM
enycesam's Avatar
You already found a solution. Get the 15s and lower your car and get it aligned.
Old Dec 12, 2008 | 09:50 PM
SOHC_4dr's Avatar
i have already said this
Old Dec 12, 2008 | 09:52 PM
MyEG6's Avatar
15's x2 x3 x4 x5 x6
Old Dec 12, 2008 | 11:28 PM
trustdestruction's Avatar
Either get the 15s as everyone said or roll the fenders. Your tire is rubbing the fender lip and the lip is tearing your tire up. Mine did this at first, I rolled fenders and it fixed the problem.
Aztec-EJ1
Jul 1, 2014 09:57 PM
01_prelude
Jun 20, 2006 06:05 AM
AznMTboy
Aug 26, 2005 06:25 AM
sk8ter4life
Jun 14, 2005 08:45 AM
professorman
Jun 29, 2003 10:59 AM
