EG foglight install
Well I searched, but damn this new search function sucks bad.
I'm just trying to see on how to wire up aftermarket fog lights, I already have them installed on the bumper.
TIA.
TIA.
how do I hook them up to the corners? just tap into the red wire? I installed fog lights in my EK and it was a breeze but I cant get my fogs for my EG connected correct.
Is there any wire-up? I can't find it damn you InternetBrands!
Ruben19 I saw that already but mine are aftermarket I don't think they wire up the same.
there should b a red wire thats by itself near the relay (that goes to battery) and on the other end(if you have the foglight switch) , there should be a red, yellow, and black wire, the red and yellow go under the dash in the fuse box(together), there should be 3 small slots that aren't being used, you should be able to see them easily, then you connect the two wires to one of the slots and check your fogs, they should just turn on with your key forward. remember connect the black wire to any ground.lmk if need more help GL
Okay its already dark out so ill try this in the morning, I connect the yellow and red into one slot? there's 1-4 if i remember correctly. Which one do I put them in?
The Red and Yellow wire's have different clips on the end of them. So I'm suppose to make the red one fit? The yellow wire fits in like oem.
born2sleep13
15
Oct 26, 2011 06:40 AM
Hookeduphatch
Jul 23, 2008 01:16 PM
thareddb
May 11, 2007 11:34 PM
alexb16hb
Jan 1, 2005 12:32 PM
01SilverGSR
Mar 25, 2003 03:04 PM
