DIY mini me swap...
Old Aug 3, 2002 | 04:18 AM
DSC's Avatar
DSC
Default DIY mini me swap...
How hard is it to DIY? D16Y8 head onto a Y7. Also, head, distributor, IM,..... ECU? That it? Thx.
Old Aug 8, 2002 | 03:02 PM
Ricey McRicerton's Avatar
Default Re: DIY mini me swap... (DSC)
Im gunna bump for this one...was also wondering....I know you need a new head, headgasket, vtec solenoid, ecu or Vafc to activate the VTEC, and probobally a new timing belt. I already have the Y8 intake mani, so let me know what else I need!
Old Aug 9, 2002 | 03:39 PM
taikahn's Avatar
Default Re: DIY mini me swap... (Ricey McRicerton)
ttt.... i want to know this info as well....
Old Aug 9, 2002 | 03:46 PM
Spade's Avatar
You need.
ECU, head and Vtec solenoid. and some wiring done to hook them up.
Some will say you just need a RPM activated switch instead of the ECU.
Old Aug 9, 2002 | 05:44 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: DIY mini me swap... (Spade)
All you need is the Y8 head. You can use your Y7 distributor. Use your old timing belt if it's still in good condition. These are your choice of vtec activation: EX ecu is about $50, VAFC about $325, NOS throttle switch $20, or shift lite with 5,000 RPM pill $60.
If you wanna build the block a bit, it's worth it since parts are cheap. A6 pistons will give you 11.2:1 CR. Strenghten your rods by getting them shotpeened. Also get an EX/Si tranny, you'll feel a big differance. Mini me is the most bang for the buck if you're not planning to swap.
[Modified by GapxGuy, 6:48 PM 8/9/2002]
Old Aug 16, 2002 | 01:20 PM
taikahn's Avatar
Default Re: DIY mini me swap... (GapxGuy)
thanx
driftam1
May 8, 2008 08:06 PM
raneys-rex
May 12, 2006 07:15 PM
Turbo Powa
46
Jan 5, 2006 11:47 AM
krazeemidget
Apr 17, 2003 07:23 AM
92JDMcivic
Apr 1, 2003 06:34 PM
