How to check for fuel in a cyl?
um ok.
i was getting some gas about an hour ago and well the car was idling horrible
so i figured it was an unplugged spark plug wire or a fouled plug
changed plug, checked wires. all cyl are getting spark
cyl 1, 2, and 3 **** the idle up when i remove the spark plug wire. there is an audible spark tho.
cyl #4 does not change the idle. the idle sounds off. it shakes the car a little. there is an audible spark and visible spark when the wire is removed.
that narrows it down to fuel
how do i check to see if a specific cylinder is getting fuel? please help asap.
i just checked the resistance on all the injectors
they all have a resistance
the #4 cyl dosent
and the harness has 12 volts all the way across.
looks like we have a winner
a toasted injector.
the #4 cyl dosent
a toasted injector.
just to update
i swapped the injectors this morning (like from cyl 3 to 4) and the problem moved to cyl #3
looks like a trip to autozone
injector 1 ME 0
injector 1 ME 0
turboedek96819
Apr 5, 2015 06:14 PM
