99 civic si mudflaps.
Old Dec 12, 2008 | 11:13 AM
Adankid's Avatar
Default 99 civic si mudflaps.
will these mudflaps fit onto my 99 civic hatchback without any modification?
i need to know cause i found out i can purchase them from my local autozone for all four of them for 23.99.
Old Dec 12, 2008 | 11:32 AM
Joel.'s Avatar
I C U P
If the mudguards are the same on 6g's as they are on 5g's the fronts will fit, but you'll need sedan rears. But I highly doubt they're going to be too exact seeing as they're from autozone. Otherwise you can probably just buy them, try them out and return them if they don't fit. You could always SEARCH too! I'm sure you're not the first person to wonder if it'd work.
Old Dec 12, 2008 | 11:42 AM
Adankid's Avatar
i did try searching but thanks for the advice.
Old Dec 12, 2008 | 11:57 AM
civic96hb's Avatar
I doubt they are OEM Si mudguards.
too cheap imo
Old Dec 12, 2008 | 04:06 PM
Joel.'s Avatar
I C U P
99.9% sure they wouldn't be OEM. But I'm guessing that the rears aren't going to be the same seeing as the rear bumper aren't the same between the coupes/sedans and the hatchbacks. I'm sure the fronts would work though.
Old Dec 12, 2008 | 10:47 PM
NOFX's Avatar
H-T White Ops
As far as OEM mudguards, there are the following sets:
- '96-'98 coupe/sedan
- '99-'00 coupe/sedan
- '96-'00 hatch
The fronts are all the same.
I'm not sure for aftermarket ones though, especially if they're flaps (longer, rubber) instead of guards (shorter, plastic).
Old Dec 13, 2008 | 07:47 AM
charms119's Avatar
Try it and come back with the details, oh and take some pics i want to check it out.
kongmoua12
Jun 1, 2014 11:53 AM
carlos8
Oct 5, 2011 01:39 PM
z6htch
Nov 23, 2008 01:29 PM
DALE-EK4
Jan 15, 2004 08:11 PM
TwistedSI
Apr 21, 2003 10:09 PM
