Hard to get into gear, automatic tranny
sup folks,
i have a 90 accord ex, automatic tranny, i have a problem that could be related to not enought tranny fluid but not sure. This morning it happened the second time and first time the other night, i got in the car, cranked it, went to push the button on the shifter in so i could put it into a gear, and the button didn't feel like it went in all the way and it was stuck in Park, is this a mechanism in the shifter itself? i let the car run a min, checked tranny fluid (i was told on automatics you check it while running) that didn't sound right to me to begin with but i trusted the person whom told me this. Anyhow it looked fine i guess, got back in the car, went into gear fine, anyone know what the problem could be? it shift fine while driving.
I posted to this just a little while ago, what happened, anyways, to make it a short one now, there is a relay and mechanical locking mechanism in the shifter assy, replace it or remove it. It also acts as a child safety feature so beware.
Check that your brake lights work.
The shifter lock mechanism Duane was speaking of consists of a lock solenoid mounted in the Shifter mechanism. It is controlled by a dual action (Single throw/double pole) switch mounted on the Brake Pedal hanger which not only controls the brake lights, but signals the shift lock solenoid to release when the brake pedal is applied.
The switch may have either failed or has become mis-adjusted.
P
P
P
P
no not old, ha, and to hondadude, the person who told me this used to race and build chevy automatic v8's for the track, so that would make since that they told me that.
miamiboy91
Apr 16, 2009 04:26 AM
The "Dash Diving" gets me every time - ouch!
