How to test my engine light with a OBD1 ecu
the car is a 2000 honda civic si
My engine light came on today but now is off.
When the light comes on again i want to find out what is going on.
I have a obd2b-obd1 jumper hardness and a p06(convert to vtec and tune) obd1 ecu.
I know that the obd2 tester wont work and i few month ago i tried to jump the connector above the ecu(brown 2 wire connector used on obd1 hondas) but the light never blinked.
I have no idea how to pull a code.
ANY ideas.
ANY ideas.
wrong section!
but here is your help!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
the ecu will give you OBD1 codes! not OBD2
Ruben19
Dec 13, 2008 06:49 PM
