turboing a da what radiator
Old Dec 11, 2008 | 09:19 PM
f90w's Avatar
Default turboing a da what radiator
I was wondering if i should use a small civic aftemarket radiator or a a full one that comes on a integra on my da. I need a radiator anyway and just needed a little hellp
Old Dec 12, 2008 | 02:38 AM
SD_Lurker's Avatar
HT White Ops
Your question is rather vague. It depends on what manifold you plan to use. You aren't going to have to much luck running a full radiator with a topmount. If its a log style manifold you can get away with it depending on which one.
Old Dec 12, 2008 | 09:17 AM
cockerkid008's Avatar
just get an aftermarket civic half sized radiator so you wont have to worry about space issues
Old Dec 12, 2008 | 12:50 PM
f90w's Avatar
thanks for the help
Old Dec 12, 2008 | 08:38 PM
riceball777's Avatar
you want to run the largest aluminium radiator that will fit.
you only want to run a half size if you have to
Old Dec 12, 2008 | 08:53 PM
HamiltonRex's Avatar
agreed. Full size if you can. However, decide on your manifold/turbo choice, get that in there and than see what you can get away with. No point getting a radiator first.
I run a full rad with 2 12" fans on my DSM, wouldn't have it any other way. Unless i HAD too...
Old Dec 12, 2008 | 08:55 PM
LilJohn198807's Avatar
What whp can you run up too on stock radiator
Old Dec 12, 2008 | 09:03 PM
g2turbo's Avatar
Definitely run the biggest radiator possible. I dont care what anyone else tells you. I ran a half in my Integra years ago with poor results. Switching to a full size made all the difference in the world.
Old Dec 12, 2008 | 09:14 PM
as much as your setup will make.
prahaian
Jan 5, 2014 01:02 PM
Tootsie7944
Feb 9, 2012 01:56 PM
yee SERIOUS
May 19, 2005 09:55 PM
fro
Sep 12, 2004 09:17 AM
