questions with b18c5 block
Thanks for reading..... I had a 1994 integra ls/vtec , spun a bearing and basicly rip my motor into pieces. currently i have a b18c5 block,crank,rods with p30 pistons . but i dont have access or money to get the head, is my b18c1 head any good with this block??? is there any wiring needed ?? please HELP!!!!
a B18C1 head will be fine with that block. it will yield pretty high compression, but it's got bigger ports and a smaller combustion chamber than a B18C5 head, so as long as all of your clearances are good, you should be golden. make sure you have a nice set of cams and valvetrain, but again, make sure that in vtec, those cams dont make those valves hit them thar pistons
