resistor box
Old Dec 11, 2008 | 06:11 PM
makeustruggle's Avatar
Default resistor box
do i need to wire up a resistor box for my h22a in hatchback
running on a chipped p28
Old Dec 11, 2008 | 06:16 PM
which wires do i splice them to?
someone help?
Old Dec 11, 2008 | 06:38 PM
LA_HONDAS's Avatar
look in the FAQ's in the civic forums
if you have a multimeter you can check ohm's if it is p&h injectors it should be around 2-3 ohm if its 10 or higher you dont need a resistor box
but most likely you will need a resistor box look in the civic FAQ's to see how to wire it up
slowesteg
Feb 2, 2012 01:35 PM
z6
Jun 19, 2004 06:37 PM
Mr_Bojangles
Jun 18, 2004 09:07 AM
95integrags-r
Jul 19, 2003 05:18 PM
Boosted LS
Jun 13, 2003 09:45 PM
