Cigarette lighter high voltage
Old Dec 11, 2008 | 05:00 PM
niceprelude's Avatar
Default Cigarette lighter high voltage
Whenever i plug something in the cigarette lighter,the fuse just blown up,because it has too much power coming out.what to do,help
Old Dec 11, 2008 | 05:05 PM
trustdestruction's Avatar
Look for shorts in the wiring, and check your ground (not sure exactly where this particular one is located).
Old Dec 11, 2008 | 05:07 PM
what is short wiring
Old Dec 11, 2008 | 05:10 PM
Swift's Avatar
a short in the wiring, it would be something like a break in the wire covering allowing cibtact with other metal parts
Old Dec 11, 2008 | 05:13 PM
Some people call that covering insulation.
lol
But yea, that's what I meant.
If you don't know what a short circuit is then you shouldn't be trying to fix this yourself.
Old Dec 11, 2008 | 05:26 PM
anyone has this problem
Old Dec 11, 2008 | 06:57 PM
gsrhatch2356's Avatar
I could be wrong but I am pretty sure that it isnt a short in the wiring cause if it was then it would blow a fuse when something wasnt pluged in. First thing I would do is check to make sure that the right fuse is in there and also sometimes some of the things that we try to plug into a cig lighter are just a little to much. I get cars all the time that come in for inspection or something that dont communicate and it always is the cig lighter fuse and I look in the car and they got cig lighter splices trying to hook up two or three things which is just too much. Just wondering what are you trying to hook up? also there could be something else on the circut that could be drawing more amps than it is susposed too but just like mentioned if you dont know what a short is then dont even attempt to try to fix it.
Old Dec 11, 2008 | 07:13 PM
plug in laptop,ipod just small device
Old Dec 11, 2008 | 07:33 PM
laptop is to much and the ipod should be fine as long as it dosent have one of those massive docking stations. anyways I really didnt like the title you posted. it is impossible for something to put out too much voltage. unless the regulator on the alt is bad and belive me if that where the case then you wouldnt be worring about the cig lighter. remeber voltage is only a sign of power where as amps is how fast that power is consumed or moved down the line.
Old Dec 11, 2008 | 07:48 PM
seem difficult
Old Dec 11, 2008 | 07:50 PM
any way,i can connect the lighter to the battery or something,so i can charge the ipod
laocivic
13
Dec 1, 2009 05:58 PM
92DAturbo
Jan 4, 2008 06:13 PM
efyou
Apr 29, 2006 04:31 PM
stockegsix
Apr 4, 2004 03:16 AM
importfan85
Dec 30, 2002 11:54 AM
